ASUS N552VX Rev 2.2
  • shadow666
    • May 2017
    • 115
    • UAE
    ASUS N552VX Rev 2.2
    Hello
    i Have a asus n552vx rev2.2
    after flash any bios on commented topic and try , Keyboard Backlight Not Working !!!!!!!!!!
    https://www.badcaps.net/forum/showth...67#post1041767
    after flash this bios notebook bootup and nvidia gpu is working .
    Someone else has a another file for test on the device to working keyboard backlight ?
    keyboard backlight it,s working with original backup bios but nvidia gpu not working !!!!!!!!!
    Regards
    • 21960
    Re: ASUS N552VX Rev 2.2
    Originally posted by shadow666
    Hello
    Regards
    Asus Keyboard Backlight fix - https://www.badcaps.net/forum/showthread.php?t=69782
    • shadow666
      • May 2017
      • 115
      • UAE
      Originally posted by SMDFlea
      Hello
      Thank you brother
      i do that and give this error !
      Code:
      SIZE=0392
      DDh Data : 0
      Can,t write data .
      What can i do ?
        • 21960
        try BT2
        • c.daniel
          • Mar 2017
          • 108
          • Romania
          try BT2
          SMDFlea, man, you rock; THANKYOU very much; i spend some hours after repair an Asus Asus GL552V with bios messed up, and after that, laptop was working perfect, but keyboard lights was off no matter what i did; i have bt.exe, first version, wich was working on some older model, on Asus N56VZ; but on this new model, GL552V, was not working.
          With your BT2, keyboard light is working again.
          Thankyou again.
          • FardinAria
            • Oct 2022
            • 13
            try BT2
            After booting, what should I type?
            • RebeuKooldu69
              • Jul 2024
              • 12
              • France
              Hello, I confirm, having a GL752VW for which I had also flashed a BIOS dump following an initial corruption.
              Following the flashing I had the keyboard backlighting which did not work --> when trying this solution proposed with "bt2": it works AGAIN.
              Thank you very much for the author of this TIP!.
