Arduino Nano Controller with a 15 watt Laser hook up issues
    • Jul 2011
    • 6055
    This project that I am working on the Engraving Machine has been a challenge to make everything to work together
    The information on the internet is hit and miss for the most part
    It is a good thing that I know how and what it takes to hook up most micro controllers yes each model is a little bit different but for the most part they are the same
    The BIGGEST problem has been the markings on these Arduino Nano Controller boards not all are the same some board are marked better than others
    You see how I have to hook up the laser and Nano Controller the pin output are not standardize which makes it more difficult to get things hooked up
    Here is one example of what I am talking about if you look at the Nano Controller board you will see the connector that I have with the cable that runs to the laser controller this output for the PWM output is 0 to 5 volts the connector right next to one that has the cable this one is marked PWM output is not 0 to 5 volts it is 0 to 12 volts
    I have another board that has two different output connectors one is marked TTL output and the other one is marked PWM output connector I have not tested what voltages these differently marked outputs and what voltages they are
    The above is just the issues that I have been having to resolve with the laser I have even more issues to resolve with the spindle motor controller this is even more complex than the laser in that the output frequency of the Arduino Nano is 490 MHz and the spindle motor controller needs 0 to 10 MHz
    The problem trying to get it work correctly and have complete control of the range is turning out to be a challenge I ordered a adjustable PWM controller that has frequently that can be adjustable as well so let see if this makes a difference in it respond to changing the PWM output duty cycle lets see if it works correctly the way I want it to work
    Then the Y X Z axis are also challenging as well in finding all the parts that will work correctly together
    I almost have all the parts for it together and let put this engraving machine together let hope I do not have any other issues that set me back again
    • Jul 2011
    • 6055
    Re: Arduino Nano Controller with a 15 watt Laser hook up issues
    Update
    The issues with the spindle controller have been resolved with a PWM frequency controller model XY-PWM
    As you can see in the picture what the best frequency setting is at 0 to 75 % duty cycle I have control over this motor speed controller has a voltage range of 5 volts to 120 volts dc ( at 93% is when the PWM output is at 5.00 volts )
    I do not consider these results bad because from 0 to 75 % duty cycle range is very smooth and each percent point increase in number value increases the spindle motor speed ( at 24 volts dc ) ( engraving machine controller is 12 to 36 volts ) I consider using a 36 volt switching power supply but I do not want to be on the limit of the controller switching power supply controller
    This is a joke what they have for the specifications for this spindle motor controller because at 1 MHz the motor at low speed wining like something else and as you increase the frequency the wining slowly goes away and if you go to 10 MHz you loose the range of smooth increase of speed
    Here is a short video of the PWM controller in use I had to make it a zip file I had to keep the file small so it only went to 40% duty cycle and back down to 0%
    Here is a link to the PWM controller
    https://www.mpja.com/Variable-Freque...info/35478+TE/
      • Jul 2011
      • 6055
      More information about this Arduino Nano Controller boards
      I took off the connector from the board and you can see in the picture that there is no connection to the PWM output pin and there is no connection to the negative pin either on the three pin connector
      In order to get a PWM output you can see where I finally found the PWM output signal and of course it only has a “S” for this pin for a Servo motor of some sort
      The first two pictures where taken with the board on a LED light table
      I am in a dispute with the seller of this board so let see what happens with this case
      This is what I pointed out to the seller that should have been able to just put power to the Arduino Nano Controller boards and hook the USB cable to the computer and should have been up and running but this was not the case I had to figure out where this PWM signal
      • Grouickman
        EPILOG Laser - XS002 controller board
        by Grouickman
        Hello gus,
        Just have two XS002 controller board for Epilog laser engraver for repair, looking for any schematic or doc on those board. So far I could only find the "Service training manual", but it's for the whole unit, not specific to the controller board and there is very little info on the board itself.
        For instance I don't even have the connectors pinout
        thx.
        06-10-2025, 11:46 AM
        SHUTTLE XPC nano NC1010BA XPC nano 4205U Specification for Upgrade or Repair
        This specification for the SHUTTLE XPC nano NC1010BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010BA boardview and XPC nano NC1010BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-12-2024, 03:36 PM
        SHUTTLE XPC nano NC3000BA XPC nano 3865U Specification for Upgrade or Repair
        This specification for the SHUTTLE XPC nano NC3000BA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC3000BA boardview and XPC nano NC3000BA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        SHUTTLE XPC nano NC1010XA XPC nano 4205U Specification for Upgrade or Repair
        This specification for the SHUTTLE XPC nano NC1010XA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the XPC nano NC1010XA boardview and XPC nano NC1010XA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      • master3112
        ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
        by master3112
        I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
        When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
        10-29-2024, 09:32 PM
