need bios file asus gl552vw rev 2.0
  • ismaelstepheno
    • Jun 2020
    • 226
    • UE
    Hi please i need bios file asus gl552vw rev 2.0
    this is the original
    with this the fun work but black screen
  • peste
    • Dec 2016
    • 13436
    • ROMANIA
    Re: need bios for asus rog GL552vx
    try..
    • ismaelstepheno
      • Jun 2020
      • 226
      • UE
      Ok thank you very much
      • peste
        • Dec 2016
        • 13436
        • ROMANIA
        the posted bios is already configured, and longer ... remove the bios chip from the motherboard before writing or reading..if you use the clip you may have errors ... check the bios with the HxD program ..try this..
        • ismaelstepheno
          • Jun 2020
          • 226
          • UE
          Re: need bios file asus gl552vw rev 2.0
          I remove the bios chip from the motherboard and readind-erase-writing but still doing the same
            • 21691
            Try this bios at post #3 its an asus service centre bios,so if you still have problems after trying it its not a bios problem - https://www.badcaps.net/forum/showthread.php?t=66398
            • ismaelstepheno
              • Jun 2020
              • 226
              • UE
              Thanks i have tried the two files posted here but still the same as you said it may be other problem in the motherboard
                • 21691
                this bios,from the link i posted https://www.badcaps.net/forum/attach...3&d=1513362466
                • ismaelstepheno
                  • Jun 2020
                  • 226
                  • UE
                  Thanks i tried this one too but still the same problem
                  • max_sneka2
                    • Mar 2022
                    • 81
                    • iraq
                    Originally posted by peste
                    try..
                    its work fine ... thank you
                    • i_badcaps
                      • Mar 2022
                      • 6
                      • Indonesia
                      thank u
                      • Sebastian Codrean
                        BIOS file for ASUS F542UN laptop
                        by Sebastian Codrean
                        Hello to all of you! I need help with a BIOS file.
                        The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                        So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                        02-20-2025, 10:25 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • MotherTeresa
                        ASUS ROG GL552VW v2 - BIOS check/repair
                        by MotherTeresa
                        Hello Could someone who knows about BIOS take a look at the attached dump. Laptop AUSU ROG GL552VW with nVidia N16P 4GB and i5 CPU.
                        I used to change GPU in the laptop, and it worked without problems for a few years. My 9-year-old daughter uses the equipment, yesterday it worked, today she says it won't start. I checked and it hangs on the ASUS logo, you can't enter BIOS (it worked once).
                        Disconnecting all peripherals, including the keyboard, resetting BIOS with jumpers under RAM, changing RAM does nothing, it still hangs on LOGO.
                        I installed a different BIOS from this model to...
                        06-29-2025, 07:30 AM
                      • caglarec2268
                        Asus X515EA Bios File Please
                        by caglarec2268
                        merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                        Now "please follow the steps below to recover your bios" text remains on the screen
                        I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                        laptop model x515ea-bq945w
                        s/n: R4N0CV02K527148
                        CN:HWFB
                        Board model; ASUS X415EA R7.0
                        bios chip: GD25Q128...
                        11-27-2024, 03:51 AM
                      • Citymin
                        NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                        by Citymin
                        My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                        The charging red LED lights up, but the charging screen doesn't show any indication.
                        When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                        (I've tried removing the battery and resetting the device, but the issue persists.)
                        NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                        PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                        S/N : 5RNK9FFT70...
                        08-05-2025, 05:12 AM
