Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 05-09-2019, 06:31 PM   #1
dennis_elx33
City & State: Kulim Kedah
My Country: Malaysia
Default Unidentified Capacitor
Hi Guys,
I am an electronics tech repairing power supply and other elex devices. It happened that I repaired 1 lambda power supply and found 1 capacitor burnt. I compared it with 1 good unit and was able to get the top marking of it. But the problem is, I cannot find any information/datasheet of the said capacitor online. I tried to source and ask electronic store online like digikey but all got negative response as they cannot find any info about it also. I tried to measure the good cap from other unit and it measures 220nF on board. The top marking is AVX CDM-22-0169744A. I hope you guys can give any info/suggestions on what capacitor should I use to replace this. Thank you in advance!
dennis_elx33 is offline   Reply With Quote
Old 05-10-2019, 02:39 AM   #2
stj
stj's Avatar
City & State: Europe
Default Re: Unidentified Capacitor
most likely CDM-22-016 is the part number and the last line is the date it was made.
given your checking of the other one, it may even be:
CDM = range
.22 = capacitance
.016 = voltage (160v??)
Old 05-10-2019, 06:31 AM   #3
dennis_elx33
Hi Stj! Thank you very much for the idea. Having said that, do you think i can use any ordinary ceramic capacitor to replace this one? It seems that this cap got special characteristic because the packaging type (8-pin DIP package) is not same with any ordinary caps. Though i don't have any datasheet to confirm. Hope to hear from you again. Thanks in advance!
Old 05-10-2019, 11:17 AM   #4
stj
stj's Avatar
ordinary?
this is just big.
Old 05-10-2019, 01:41 PM   #5
R_J
City & State: ☻
My Country: Canada
What part of the circuit is it located?
That might be either an old number or custom part number.
You say the value you measured is .220 f correct?
If you can't find a replacement, try contacting AVX, they likely have a direct replacement
R_J is offline   Reply With Quote
Old 05-10-2019, 04:24 PM   #6
R_J
City & State: ☻
My Country: Canada
It could just be a very low esr capacitor that is used in the output of the power supply, I see they will use these stacked mlcc types in place of large electrolytics
Old 05-10-2019, 06:10 PM   #7
dennis_elx33
Hi Stg, thanks for the reply..i will just try to find other options.
Old 05-10-2019, 06:23 PM   #8
dennis_elx33
Hi RJ,
Kindly see the actual photo of the pcb circuit. Yes, I will try to contact AVX about this. Its 220nF so by conversion its 0.22uF. Thank you very much for the suggestions.
Old 05-10-2019, 10:02 PM   #9
R_J
City & State: ☻
My Country: Canada
I suspect it is the high voltage type.
Old 05-10-2019, 11:48 PM   #10
dennis_elx33
Hi RJ, Thank you very much for your idea and for this datasheet. Anyway, I already sent email to AVX and still waiting for their reply. I will update you the result later. Thanks again!
Old 05-11-2019, 02:15 AM   #11
stj
stj's Avatar
Lambda??
what is this? maybe we can find a schematic.
Old 05-11-2019, 02:48 AM   #12
dennis_elx33
Hello stj! Yes, this is lambda power supply. Thanks in advance.
Old 05-11-2019, 07:58 AM   #13
stj
stj's Avatar
model?
Old 05-11-2019, 10:07 AM   #14
R_J
City & State: ☻
My Country: Canada
Someone was looking for the same part but a different power supply a few years ago (HAL-02-655), I suspect the number is lambda's own number on that part.
Old 05-12-2019, 10:15 PM   #15
dennis_elx33
Hi Stj, the model is pfhc-2600..thanks
Old 05-12-2019, 10:17 PM   #16
dennis_elx33
Hi RJ, I guess so..I'm still waiting for AVX's reply on my inquiry email. Still hoping they will reply by this week.
Old 05-13-2019, 09:21 AM   #17
R_J
City & State: ☻
My Country: Canada
If you don't here from AVX, try TDK-Lambda, they might be able to supply the part.
Here is the other picture I found, same numbers except the last which I suspect is the date/mfg. code.
Old 05-13-2019, 06:33 PM   #18
dennis_elx33
Hi RJ, ok I will try your suggestion. Thanks a lot!
Old 05-14-2019, 01:55 AM   #19
stj
stj's Avatar
yes, good photo.
last line on the cap: 9726A < 26th week of 1997??
printed on the pcb: 3197 < 31st week of 1997??
dennis cap is 9744A and the pcb is 9825.
i am now 100% sure i was right.
the capacitance, possibly the voltage, then the mfr date.
Old 05-15-2019, 01:52 AM   #20
dennis_elx33
hi stj, thanks for your idea..anyway I tried to buy the mlcc cap with 220nF/630V rating because I cannot find the exact part online.. I will inform u guys later whether pass or fail after I install the part and do the testing.
