Acer aspire ES1-431 bios and ec needed
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I need a working main bios and ec on this laptop ACER ASPIRE ES1-431
    BOARD ID: MODEL:Z8AD
    DAZ8ADMB6D0 REV please
  • String2016
    • Nov 2015
    • 2238
    • philippines
    Re: Acer aspire ES1-431 bios and ec needed
    need help please
    • peste
      • Dec 2016
      • 12973
      • ROMANIA
      Originally posted by Mulong2019
      need help please
      not tested.
      • String2016
        • Nov 2015
        • 2238
        • philippines
        @peste you bios is not working. here is my original backup main bios and ec bios both 1.8vchip. can someone fix this please
          • 21208
          Try this one,latest update merged ,TXE clean , DMI + Key .
          • String2016
            • Nov 2015
            • 2238
            • philippines
            thanks smdflea i tried to flash with your bios still the same issue turns on fan spins but still no display
            • peste
              • Dec 2016
              • 12973
              • ROMANIA
              maybe the bios does not have the problem
              • String2016
                • Nov 2015
                • 2238
                • philippines
                I noticed this board it has ITE8987E which is programmable could someone has a I/O chip bios on this?i will try to program the ITE chip please help or someone clear the ME REGION of my original dump please
                  • 21208
                  EDIT: The ITE8987E is programmable, and it can use either internal 128KB or external flash as it is on this motherboard .
                  EC at post #5 + clean TXE (ME) region bios . Some DMI info is stored in the 1MB EC, flash both.
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    @smdflea I already done flash both ec and main bios still the same issue turns on with no display and fan spins.i would give a try if it has a ITE8987E FILE , I Will to try to flash with SVOD
                      • 21208
                      It is desinged to work with the external flash.I agree with @peste , in this case i don`t think the bios/ec is the problem .
                      • quezon
                        • Dec 2015
                        • 70
                        • Philippines
                        thanks
                        • djharold
                          • Aug 2015
                          • 241
                          • COLOMBIA
                          • dycc
                            Vision
                            • Nov 2011
                            • 625
                            • Côte d'Ivoire
                            [QUOTE=peste;888382]not tested.TESTED IT WORK
                            • juntmeako
                              NOOB
                              • Jul 2020
                              • 67
                              • na
                              hello, i have the same issue, fan spin, hard drive spin, charger lights , but no display and no power led light
                              • juntmeako
                                NOOB
                                • Jul 2020
                                • 67
                                • na
                                hello again, i just fix my issue, it come on but no display, all voltage present, anyone whi has same issue with mine, olease try to download the bios file i used to fix the problem, hope it helps
                                • janpatirkckaram1992
                                  • Sep 2020
                                  • 9
                                  • Philippines
                                  tnx sire working and tested.
                                  • hoaca388
                                    Badcaps
                                    • Jan 2022
                                    • 11902
                                    Good job
                                    • hoangnhan93100
                                      • Oct 2022
                                      • 4
                                      • viet nam
                                      Thanks bro, it worked
                                      • Ko Thaw
                                        • Aug 2016
                                        • 6
                                        • Myanmar
                                        • EbrahimSiami
                                          Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                          by EbrahimSiami
                                          I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                          **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                          **What I have tried so far:**
                                          1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                          07-02-2025, 02:31 PM
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                        • NecroFlex
                                          Acer Aspire 1 A115-32-C28P BIOS needed please
                                          by NecroFlex
                                          I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                                          I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                                          I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                                          02-11-2025, 08:51 AM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
