Asus x555ld
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    Asus x555ld
    This notebook start but no video so I replace the bios
    now start and visualize but NVIDIA 940M not detected
    probably not exact dump.
    Someone can repair the original bios ?
  • ziggster
    • Feb 2019
    • 72
    • israel
    Re: Asus x555ld
    what is the motherboard full model ?
    • alihomee
      • Dec 2012
      • 1598
      • malaysia
      Re: Asus x555ld
      here u go try and post results
      • jasko_jacker
        • Oct 2014
        • 1140
        • italy
        Re: Asus x555ld
        I try it , but the system don't recognize the wifi chip and lan chip and nvidia chip if your bios don't work I assume to try a EC reset with ftp -greset.
        It's possible that all those devices are bad ?
          • 22275
          Re: Asus x555ld
          Try this one,its your bios with clean ME .
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            Re: Asus x555ld
            LCD -> FULL WHITE
            EXTERNAL -> displays but starts from the windows logo, it is impossible to access in the bios.
            thanks
              • 22275
              Re: Asus x555ld
              Ok, at least you are getting somewhere now.I can merge the bios update with the cleaned ME bios next.What is the CPU type ix-4xxxxU or ix-5xxxxU
              • jasko_jacker
                • Oct 2014
                • 1140
                • italy
                Re: Asus x555ld
                ix-5xxxU nvidia 940M
                thanks
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  Re: Asus x555ld
                  On the box : A555LB
                  On asus last bios is version 603
                  with this bios works but no lan no wifi no nvidia, with mmtool nvidia seems ok ->10DE:1347 as the original
                    • 22275
                    Re: Asus x555ld
                    Yes i noticed LB in the bios. I`ll post another bios soon .
                      • 22275
                      Re: Asus x555ld
                      Try this new one ,with 603 merged.
                      W 223000 - 2230FF
                      • jasko_jacker
                        • Oct 2014
                        • 1140
                        • italy
                        Re: Asus x555ld
                        W 223000 - 2230FF
                        Lcd ok remain the problem of lan and wlan and nvidia.
                        Lan -> it's possible hardware fault
                        Wireless Lan -> works on linux so no hardware fault, I see on ME is
                        disabled but on FITC seem all ok
                        NVIDIA -> it's possible hardware fault
                        I use Hardware info, attach the me screeshot
                        try to replace EC or force EC with ftp -greset
                        • jasko_jacker
                          • Oct 2014
                          • 1140
                          • italy
                          Re: Asus x555ld
                          Finally I solve the problem,
                          ME was disable because the resistor that enable it was broken (ME_AC_PRESENT_PCH)
                          I really appreciated your help, and I ask you one last thing; which bios I use new_bios or new_2 both work fine.
                            • 22275
                            Re: Asus x555ld
                            Great fix. Sometimes you can lose the MAC address by flashing a different bios,there`s an asus tool to write the mac adress back in those cases.If both bios are working use the newer one .
                            • Nomi929
                              • Apr 2019
                              • 5
                              • Pakistan
                              Re: Asus x555ld
                              Anbody have EC.Bin file for Asus X555LD Motherboard?
                              Best Regards.
                              • peste
                                • Dec 2016
                                • 13915
                                • ROMANIA
                                Re: Asus x555ld
                                Best Regards.
                                Try...
                                • Nomi929
                                  • Apr 2019
                                  • 5
                                  • Pakistan
                                  Re: Asus x555ld
                                  Originally posted by peste
                                  Try...
                                  Thanks. Will try and let u know.
                                  My Mb is rev 2.0 and 4th gen i7.
                                  • Nomi929
                                    • Apr 2019
                                    • 5
                                    • Pakistan
                                    Re: Asus x555ld
                                    Try...
                                    It didn't worked on K555LD rev 2.0.
