Lenovo G585 bios
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Lenovo G585 bios
    I did, but there was no change.
    I do not know why the FCH does not recognize the mainboard as a UMA mainboard after converting it to UMA. Maybe, I also need to change something else too such as reprogramming Bios using a UMA dump.
    I have attached my Bios dump for Lenovo G585 with a GPU. If someone has a Bios dump from a Lenovo G585 that has no GPU, please upload it here for me.
    MOD EDIT: Bios moved from original thread - https://www.badcaps.net/forum/showthread.php?p=876603
  • mielta
    • Apr 2015
    • 368
    Re: Lenovo G585
    Hi
    Try This
    • AHmad_Salal
      Need BIOS Dump/ROM for Lenovo Thinkstation p500
      by AHmad_Salal
      Hello all,
      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
      11-28-2023, 05:28 AM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Habble7
      I need a BIOS dump for the Samsung S49CG934SU monitor
      by Habble7
      The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
      Suspected Cause:
      I suspect the BIOS may have been corrupted during a power interruption while updating the firmware. The official website provides firmware updates, but they can only be installed via USB flash drive.
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • Joluvillas
      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
      by Joluvillas
      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
      06-18-2024, 10:35 PM
    • Captaincrap420
      Lenovo Tiny8 triple NVMe IQ6X0IL1 HQ670 NM-D581 Rev 0.5 M90q Gen 3 / P360 Tiny prototype board BIOS dump
      by Captaincrap420
      Hi, I hope this is the right place to post this. This is my first post on this forum.
      A friend helped me get a prototype Lenovo motherboard from China, it's got a hole drilled in it but I'm working on trying to revive it to some degree. I dumped the bios in hopes that it might be useful to someone, since this board is configured with the 3rd NVMe SSD slot and maybe it is useful as a reference for modding another bios to support this function. For example the M90q Gen 2 / P350's unpopulated 3rd NVMe slot footprint maybe.
      This bios dump is straight from the chip, nothing has been...
      11-29-2024, 05:40 PM
