HP PROBOOK 440 G3 bios lock
  • salawayon
    • Nov 2012
    • 578
    • philippines
    infos:
    DA0X61MB6G0 REV G...
    i attached my backup...
    thanks...
  • snsent
    • Nov 2010
    • 103
    • Malaysia
    Re: HP PROBOOK 440 G3 bios lock
    Try this... Backup first...
    • salawayon
      • Nov 2012
      • 578
      • philippines
      i've tried your file but it ended in no display problem ....
      • basic
        • Oct 2017
        • 229
        • 86357289244
        try this ...
        • sourcebf
          • Jul 2016
          • 433
          • N/A
          try it i fixed your bios
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Dear Salawayon, Your bios password cleared-will work 100%.
            Enjoy
            • salawayon
              • Nov 2012
              • 578
              • philippines
              it works... my problem is now with product infos is missing... what version of nbdmifit will work on this model?
              thanks...
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Its difficult to say that. You need to try different versions of nbdmifit
                • sssssssssssssss
                  Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                  by sssssssssssssss
                  I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                  Symptoms:
                  • Laptop powers on but no display at all (completely black screen)
                  • Caps Lock blinks twice with a pause, then repeats continuously
                  • F12 LED stays on permanently
                  • No POST, no boot sequence, nothing on screen
                  Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                  What I've tried:
                  • Hardware reset (battery removal, power
                  09-04-2025, 06:45 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers šŸ˜€,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
                  šŸ”§ Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  šŸ’€ Problem:šŸ˜…
                  - Device shows ā€œAdministrator Passwordā€...
                  08-07-2025, 04:54 AM
                • ArtMov
                  [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                  by ArtMov
                  Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                  1. I made overclocking lock disabled the default in amibcp
                  2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                  03-31-2023, 01:30 PM
                • pirati
                  by pirati
                  10-27-2025, 04:20 PM
                • Vesko356
                  by Vesko356
                  08-11-2023, 03:27 AM
