Hi everyone, I have a Samsung giving me issues....It is a "one connect" with the box. I power it on and i get no sound or display. If i power it on with out hooting up to the one connect i do get a display showing to hook up the one connect box. I also get a flashing red LED in the lower right that flashes like once then a quick flash then 5 more flashes...the TV will try to power on two times before the red IR LED starts flashing. I have removed all the boards one by one and inspected the solder joints and capicators and all are good. any help woud be greatly appriciated. Thanks Jeremy.
Samsung UN65HU9000F
Re: Samsung UN65HU9000F
I have had a few customers bring in these sets for repair and 9 times out of ten it was an issue with the one connect box overheating and causing cracked solder joints between one of the BGA chips and the board itself. These one connect boxes are poorly designed in my opinion and have very little breathing room inside those boxes.
The last time we had that issue walk in the door the TV would cycle through on and off sometime would work for 10 minutes sometimes it would go directly to just a blinking light. We have also seen it cause weird colors on screen. Not sure if you are getting any of that.
Hello guys
Sorry for jump in to this.
Please Can someone help me find out what's my TV fault?
It's Samsung UA55HU9000W
When connect one connect box screen full of lines
When disconnect it's fine
Also only channel change and volume up/down works on remote
But sometimes when keep on/off again and again tv works fine and no lines
I have attached pictures. Please have a look
Dulip
