Lenovo G580 Blank Screen
  • shadowpool
    • Mar 2017
    • 6
    • US
    Hi all!
    I have a Lenovo G580 Model 20157 with a LG4858 UMA MB and I was wondering if someone could help me troubleshoot it.
    I have actually been given one of these before and it had the same symptoms--I press the power button and the webcam light, fan, and power light come on immediately. The fan stays on for about 9 seconds then stops. The fan will start again a minute or two later, stay on for a good while, then stop again. After this second fan cycle the laptop turns off. Throughout this whole process there is no video output. I don't have an external monitor to try, unfortunately. This is with no peripherals attached.
    With this particular laptop, it was working when I got it, but then I went to install a new wireless card and stripped the screw. So I carefully taped up the motherboard and hit the screw with a dremel while collecting the metal filings with a hard drive magnet. Then I used hand powered air duster to clean the board off thoroughly before applying power. After I did this, that's when the problem started. No wireless card is currently installed. The BGA chips were all under a glued down plastic insulator sheet so I think they were safe.
    The screw post I dremeled on is mounted above the HDD1 connector on the top side and KB58 the keyboard connector on the bottom. All the graphics power is on the other side of the board...
    Some measurements:
    5V_S0 OK
    3D3V_S0 OK
    1D8V_S0 OK
    1D5V_S0 OK
    0D85V_S0 OK
    0D75V_S0 OK
    VCC_CORE OK
    RTC bat 3V
    VCC_GFXCORE dead--2mV on both sides of the inductor PL4401 vs ground.
    Associated MOSFET PU4402 gets DCABATOUT OK.
    No signal on the driver PU4401: PWR_GFX_CORE_DRVL, PWR_GFX_CORE_DRVH, and PWR_GFX_CORE_GPWM all have no signal.
    VCC_GFXCORE to ground with processor removed 364 ohm. (too low?)
    No visible shorts to the visible balls under the processor socket or PCH.
    PCH chip gets really hot. Not sure if that's normal.
    Swapping ram slots / different ram does nothing.
    Hall effect sensor OK.
    Any advice would be much appreciated. Thanks!
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Lenovo G580 Blank Screen
    If you connect usb kb and mouse, are they recognised ?
    If yes, i would say pch swap is need, reball doesn't work all the times
    • shadowpool
      • Mar 2017
      • 6
      • US
      Capslock does not turn on the capslock light. I see the COL1 test point go from 2mV to 4mV when I press the capslock key so it looks like that signal is getting through.
      Hoping it's not the PCH chip. I don't have the technology to do a reball/swap.
      • nataf10
        • Mar 2012
        • 37
        • Israel
        Hi there, I have the same laptop with the same issue.
        Did you find the reason why the display is not turn on?
        Did you tried to flash the bios chip?
        Please let me know.
        Thx
        • pratyush
          • Sep 2018
          • 69
          • India
          Originally posted by shadowpool
          Hi all!
          Some measurements:
          5V_S0 OK
          3D3V_S0 OK
          1D8V_S0 OK
          1D5V_S0 OK
          0D85V_S0 OK
          0D75V_S0 OK
          VCC_CORE OK
          RTC bat 3V
          Have you got solution? I also have same issue.
          • piernov
            • Jan 2016
            • 4439
            • France
            EDIT: just realized you already posted on another topic…
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • Kalman27
              Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF OLED Blank screen
              by Kalman27
              We have a Lenovo IdeaPad Slim 5 14IAH8 - Type 83BF for repair. The original issue the OLED screen is blank.
              We have replaced the OLED screen with the exact model, also we replaced the LCD cable, but no luck.
              I think there is something with the motherboard. I don't really have experience with OLED screens so far, so not sure how it should work. I have seen some laptop comes with a separate controller board, but this model does not.
              Also, there is an error in Windows device manager - This device cannot start (Code 10) - Intel(R) Serial IO I2C Host Controller...
              06-17-2025, 05:52 AM
              Lenovo IdeaPad G480 G580 Laptop Boardview
              WISTRON LG4858L G48,G58 UMA 12206-SA...
              10-29-2024, 04:02 AM
              Lenovo G580 Laptop Schematic
              LA-7981P...
              10-08-2024, 12:09 PM
              Lenovo 3000 Series Schematic
              Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
              3000 C100 laptop with Braille keyboard
              Lenovo 3000 C
              C100, C200 - 15-inch XGA screen
              Lenovo 3000 N
              N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
              N500 - 15.4 inch screen.
              Lenovo 3000 V
              V100, V200 - 12.1-inch WXGA models
              Lenovo 3000 G
              G400, G410, G430, G450, G455, G510, G530, G550, and G560...
              10-04-2024, 06:05 AM
