acer v3-772g
  • germamiga
    • Mar 2016
    • 29
    • france
    acer v3-772g
    hello
    i have a laptop acer v3-772g with va70hw motherboard
    i change mosfet for the power up............
    but my power supply turns in short circuit !!! the led blinking on my acer power supply.........
    do you have an idea ???
    sory for my poor english..........
  • meritosari
    • Oct 2010
    • 774
    • Indonesia
    Re: acer v3-772g
    It seem +AC_BAT_SYS shorted to ground
    There are only 2 pieces resistor on these board. the value are 10 miliOhms
    The one for +AC_BAT_SYS (+A/D_DOCK_IN_Q_Q), and the other for +BAT (+BAT R).
    These part easy to find it which marked R010
    You could remove one to isolate the shorted. then identify goes to where is line have the short
    Did you have pics with High resolutions, then upload it here
    • germamiga
      • Mar 2016
      • 29
      • france
      Re: acer v3-772g
      ok i see it !
      i test it !
      thanks
      • germamiga
        • Mar 2016
        • 29
        • france
        Re: acer v3-772g
        I removed R010 ..........
        more short circuit
        but if I give a new R 010 (0.7 ohm) Short Circuit back ..........
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          Re: acer v3-772g
          I assume you 've removed the resistor then put your DMM on the pad which side the resistor is shorted to ground? Do this without adapter plug in
          • germamiga
            • Mar 2016
            • 29
            • france
            Re: acer v3-772g
            I do not understand.
            I removed the R010
            I tested with the adapter and no bliking.
            i put a new 010R and I blink
            i think it's r8808
            did you want i remove r8808 and i put a weld a cable to ground ????
            • meritosari
              • Oct 2010
              • 774
              • Indonesia
              Re: acer v3-772g
              Sorry for my English and make you was confuse
              Please Don't test with adapter, till the shorted has gone
              We are chasing part that causing shorted. Since the board have no mark, we need do this thing be carefully. we only test or measure with multimeter (DMM/DVM)
              No. I mean after you've removed the resistor, we need to know where point (pad,pin) that connecting to ground (cause it's have short then it's grounded). Do test with your Digital Multi Meter (DMM) in Diode mode or continuity
              we need 100% sure the AC_BAT_SYS have no shorted.
              I think it's r8808
              I think that too.
              That best idea is to make photos whole board (top and bottom sides)
              • germamiga
                • Mar 2016
                • 29
                • france
                Re: acer v3-772g
                i test it quickly
                removed r010
                in diode mod,
                i put the red pin of my DMM to +a/d-dock_in_q_q and black pin to ground................ 2.4 v.............
                • germamiga
                  • Mar 2016
                  • 29
                  • france
                  Re: acer v3-772g
                  • meritosari
                    • Oct 2010
                    • 774
                    • Indonesia
                    Re: acer v3-772g
                    You didn't measure on other pads of R8808 (R010). if you get value is 0.000v, then this mean is 100% ac_bat_sys have short circuit.
                    • germamiga
                      • Mar 2016
                      • 29
                      • france
                      Re: acer v3-772g
                      Good evening,
                      I measured on the other side of r8808 and I 0 v!
                      so i have a shot circuit ......where ??? bq24735 ?
                      • meritosari
                        • Oct 2010
                        • 774
                        • Indonesia
                        Re: acer v3-772g
                        There are many components that may be the cause short circuits in the path of this ac_bat_sys, not sure 100% just the BQ chip.
                        https://www.badcaps.net/forum/attach...1&d=1474145129
                        I made some screenshots that could be help you trying locating short circuits.
                        Quickly way find the shorted is using PSU which have current limiting and voltage
                        https://www.badcaps.net/forum/attach...1&d=1474146064
                        Originally posted by meritosari
                        Hard to say " can't share the boardview, cause I don't want to break the rule on one "forum" that I registered as membership. (free forum that was need colecting some points to download doc/file).
                        anyway, I can share just screen shoot:
                        Tips from Th3_Un1qu3:
                        Another way of locating shorts (or at least narrowing down on them), is isolating the individual blocks of the board.
                        It is highly recommended you have a schematic for this. It's very hard (but not impossible) to do this without one. First remove everything from the board. RAM, CPU, Wifi, etc. If it is still shorted, follow:
                        • Follow the rail that you find shorted on the schematic.
                        • Look for jumpers and/or inductors connecting that rail to the rest of the circuit. Unsolder jumpers/remove inductors.
                        • Check which end of the jumper/inductor still shows a short.
                        • Repeat until you isolate the short to just one block.
                        • Test MOSFETs on that block.
                        • If you found shorted ones, replace them.
                        • Remove all large ceramic caps.
                        • Short cleared? Congrats. Replace caps, put the inductors back in, resolder the jumpers and you're good to go.
                        I have just fixed an Acer Aspire 5315 by this method, B+ was short to ground. A large ceramic cap in the battery charger circuit was responsible for the short.
                        https://www.badcaps.net/forum/showth...locating+short
                        • germamiga
                          • Mar 2016
                          • 29
                          • france
                          Re: acer v3-772g
                          hello
                          thanks for all
                          i test : removed q 8806...........short power
                          removed l 8800 short power
                          removed q 8804/q8805 short power
                          removed jp 8802 jp 8803 short power
                          for the moment removed :
                          q 8806
                          l 8800
                          q 8804 q 8805
                          jp 8802 jp 8803........................
                          and the power suply is in short circuit
                          but i don't find c8806 !
                          • germamiga
                            • Mar 2016
                            • 29
                            • france
                            Re: acer v3-772g
                            i replace bq24735...................same problem
                            • meritosari
                              • Oct 2010
                              • 774
                              • Indonesia
                              Re: acer v3-772g
                              I recommend you to remove CPU, RAM, Wifi card first.
                              - Try to measure of All big coils to ground (Diode mode)
                              - Check all HS mosfet if ok
                              - Give focus on all ceramic capacitors that written in "Comp.txt". Try remove one by one with slide technic, would it be minimize risk lose these capacitors. if you put in other places probably you'll miss it. Capacitor would be change color and little crack if them has broken.
                              -If short sircuit still in there, only IC PWM has big chance have been shorted (already on .txt)
                              ps. I give you wrong info about HS mosfet, seem G**gle translate not working properly, LOL.
                              • germamiga
                                • Mar 2016
                                • 29
                                • france
                                Re: acer v3-772g
                                ok thanks !!
                                • germamiga
                                  • Mar 2016
                                  • 29
                                  • france
                                  Re: acer v3-772g
                                  hello i found the problem !
                                  it's q 8300
                                  irfhs 8342..............
                                  i wait the component for test.............
                                  • germamiga
                                    • Mar 2016
                                    • 29
                                    • france
                                    Re: acer v3-772g
                                    Fantastic !!!
                                    the motherboard is ok !!!
                                    but i have a problem with another motherboard.
                                    when i plug the power supply, the pc boot itself and no display!!!
                                    • highpulse
                                      i hate HP
                                      • May 2013
                                      • 1490
                                      • portugal
                                      Re: acer v3-772g
                                      pc boot itself , there is no CMOS battery or RTC circuit with short onGND . if AMD machine it will not display any image .
                                      if intel bios might be corrupt
                                      • germamiga
                                        • Mar 2016
                                        • 29
                                        • france
                                        Re: acer v3-772g
                                        it's an intel bios
                                        i test tuesday with another bios
                                          09-06-2024, 05:27 AM
                                          Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                          This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 04:10 AM
                                          Acer Aspire A317-53-52WQ + Pack Gold Acer 17'' Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Acer Aspire A317-53-52WQ + Pack Gold Acer 17'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A317-53-52WQ + Pack Gold Acer 17'' boardview and A317-53-52WQ + Pack Gold Acer 17'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
