Asus N76VB identifying 'A5 GNA'
  • likewise
    • Apr 2016
    • 11
    • The Netherlands
    Hello all,
    On my Asus N76NV I am suspecting a bad MOSFET (near-zero drain-source resistance) but cannot identify the part 100%.
    The part is marked:
    A5 GNA (sure)
    GP0108 (not sure)
    See photo in attachment.
    This is the RBFET that matches the TI BQ24725A reference design.
    Motherboard rev. 2.0.
    Laptop only ran on remaining battery charge, did not charge, did not power-up without battery. It did power-up when I put 19V on the drain of this MOSFET.
    ACOK=2.87V
    ACDET=2.57V
    I would like to find a proper replacement locally (.eu / .nl), any help appreciated to identify and find a replacement!
    edit: might be PJ8804 according to the silk screen, I am interpreting this right?
    Thanks all!
  • kotnatan
    Banned
    • Apr 2014
    • 181
    • Ukraine
    Re: Asus N76VB identifying 'A5 GNA'
    1 - pq8806 - n-mosfet p0903bea
    2 - pq8807 - n-mosfet p0903bea
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      well before adding mosfets , simple remove both , if its the front dc jack fets . and with them removed , chek they gates they shoulb be 19 volts . if its not , then bypass them all to see if there is short after the fets !!! if there is a short on the 19 volts line , the first fets will cut off power to flow
      • and555
        • Apr 2016
        • 36
        • Indonesia
        Originally posted by likewise
        The part is marked:
        A5 GNA (sure)
        GP0108 (not sure)
        This is P-Channel mosfet, replace with AON7403.
        • and555
          • Apr 2016
          • 36
          • Indonesia
          you say it's N-mosfet based on boardview, right ? did you ever measure it? It's P-Channel mosfet.
          • likewise
            • Apr 2016
            • 11
            • The Netherlands
            How can we find out without desoldering?
            How would the (schematic) design differ from the bq24725a reference design, where the datasheets specifically mentions it drives N-channel FETs ACFET and RBFET?
            Can someone explain why there are two identical MOSFETs placed with a common source, in opposite directions? I'm trying to understand how this design works.
            Thanks, would like to clear up what is the correct part.
            • kotnatan
              Banned
              • Apr 2014
              • 181
              • Ukraine
              sorry
              p- mosfet
              • likewise
                • Apr 2016
                • 11
                • The Netherlands
                sorry
                p- mosfet
                I am confused. P0903BEA shows as an N-channel enhancement MOSFET from this datasheet:
                • kotnatan
                  Banned
                  • Apr 2014
                  • 181
                  • Ukraine
                  this is what shows ASUS N76VB (60NB0130-MB1030) REV 2.0 - BoardView
                  • likewise
                    • Apr 2016
                    • 11
                    • The Netherlands
                    In your screenshot there is "N-MOSFET" in front of "P0903BEA".
                    Also, the datasheet of P0903BEA mentions "N-channel MOSFET".
                    Could it be the confusion is from the "P" in the part name (P0903BEA)?
                    • likewise
                      • Apr 2016
                      • 11
                      • The Netherlands
                      But what part number is on the board?
                      If it's a P0903BEA MOSFET, why do you think it is a P-channel MOSFET?
                      If it's a different MOSFET, do you know what kind it is?
                      How did you measure the P vs N MOSFET characteristic?
                      I am not a laptop expert, but I do have some EE background.
                      • kotnatan
                        Banned
                        • Apr 2014
                        • 181
                        • Ukraine
                        A5 GNA = A5 GND
                        marking significant "A5" P0903BEA. Everything else - the date, lot, ...
                        N-MOSFET P0903BEA - AON7408 & FDMC8884
                        • trebo
                          • 514
                          • Wales, UK
                          • likewise
                            • Apr 2016
                            • 11
                            • The Netherlands
                            A5 GNA = A5 GND
                            Thanks. I have two remaining questions:
                            1) Where can I find that A5 means P0903BEA?
                            2) In posting #7 you mentioned "p- mosfet", this confused me.
                            So we agree this is an N-channel MOSFET?
                            Thanks all! Great help here.
                            • kotnatan
                              Banned
                              • Apr 2014
                              • 181
                              • Ukraine
                              an example of the circuit
                              • likewise
                                • Apr 2016
                                • 11
                                • The Netherlands
                                I already posted this datasheet in post #8?
                                This does not answer my question though... How can I tell it is this part?
                                Thanks.
                                • and555
                                  • Apr 2016
                                  • 36
                                  • Indonesia
                                  P0903BEA is exactly N mosfet.
                                  A5 GNA is exactly P mosfet.
                                  on the boardview of Asus N76VB, the location this "A5 GNA" on the boardview indicate P0903BEA.
                                  but actually, A5 GNA is P mosfet (kotnatan already confirm it on post 7).
                                  so, likewise: you can replace it with AON7403.
                                  • likewise
                                    • Apr 2016
                                    • 11
                                    • The Netherlands
                                    I do not understand why you guys think the A5 GNA is a P-channel MOSFET. I have not seen any evidence in this thread. On the contrary the BQ charger IC datasheet specifically mentions it drives N-channel type ACFET and RBFET.
                                    I have therefore replaced the 2nd jack (RBFET) with a Microchip MCP87130T-U/LC MOSFET, N-CH, 25V, 54A, 8PDFN.
                                    Laptop works again.
                                    My problem is solved, some of my questions in this thread remain valid.
                                    Regards, Leon
                                    • likewise
                                      • Apr 2016
                                      • 11
                                      • The Netherlands
                                      That's an N-channel symbol it seems to me. I do not understand why it is depletion though.
                                      • lining
                                        • Mar 2017
                                        • 2
                                        • Macedonia
                                        same confusion with my problem.... I have bad A5 GNA 3ROG05 mosfet on Asus ROG G551 and I don't know it's N or P channel mosfet....bad adapter made the mosfet to be shorted. I have tried to replace with a5 GND which is N channel and the problem it's still the same, working only on battery charge but it's not charging
