Trouble shooting a Samsung PN58B650S1F
  • ROLEXrifleman
    Fire Hazard
    • Mar 2016
    • 34
    Hello everyone. looking to get some help on a bit of troubleshooting on a dead Samsung. It has the infamous no turn on just clicking going for it.
    TV is apart and I have started to trouble shoot. 1st thing was I verified all the fuses are good.
    The next thing I did was tried to disconnect the x and y boards individually to see if the tv turned on. No luck there either. Unplugged the y board, clicky clicky, no turn on. reconnected the y board, discoed the X board and same thing, click click click... no turn on.
    At this point, with all the boards connected I checked voltages out of the power supply. Output to the X, Y, Logic and A/V contrl Boards were all constant at 15.14, 15.13, 5.15, 5.4 volts DC no mater how bad the relays were clicking. The voltages that were way off were the Va and Vs. Va should have been at 55. I was only able to measure 32. Vs was suppose to measure 202, i was only getting 92. The other strange thing was that the power supply was clicking in a set pattern of 5 cycles then it would take an 8 sec break and start over. each time it clicked in the 5 part cycle the voltage grew a little with the Va and Vs, but never reaching what it should be.
    Va would be 29, 30, 31, 31, 32 while Vs would be 80, 87, 90, 91, 92 then the cycle would stop for about 8 seconds and repeat all over again.
    My question is, is this enough trouble shooting to say it's a bad power supply or are there other things that need to be done to draw that conclusion? I'd like to fix the TV without throwing money at parts it doesn't need.
    Thank you in advance for any and all help you can provide me.
    HC
    I cant break it anymore than it already is!
  • martino
    Not so "senior"
    • Aug 2013
    • 997
    • canada
    Re: Trouble shooting a Samsung PN58B650S1F
    Find pin VS-ON on power supply,what does it measure? steady or fluctuating with the clicking.
    Proud owner of dozens of broken TV's and many,many,many boards.
    Our website and passion:http://hollenhundshepherds.com/
    • ROLEXrifleman
      Fire Hazard
      • Mar 2016
      • 34
      There are four output connectors on the PS. The output connectors to the Logic Board and A/V Controller have labels for VS-ON pins. The X and Y Connectors only say VS.
      The Logic and Controller outputs are 3.23DC and 3.23DC. These voltage outputs do NOT fluctuate with the clicking of the PS. The X and Y outputs on the other hand DO fluctuate with readings starting at 36DC down to 26DC with the clicking of the PS.
      • ROLEXrifleman
        Fire Hazard
        • Mar 2016
        • 34
        resubmitting pics in the appropriate format
        • martino
          Not so "senior"
          • Aug 2013
          • 997
          • canada
          So commands to powersupply to switch on are steady. Safe to say the problem is on the power supply.
          Are you looking to repair on component level or plan to replace the board?
          Seen a few on fleebay in the 60 buck range
          • ROLEXrifleman
            Fire Hazard
            • Mar 2016
            • 34
            I know my limitations, and at this level in the game I'm just a board jockey. I wouldn't mind taking a stab at it but I'd probably have more to loose then gain. I did pull the board just to make sure there were no broken or loose solder joints though. All was good there.
            I know going used parts is a crap shoot as well, but if $75usd gets me another year or two out of the TV I'll be happy.
            So I should feel confident getting a replacement PS then?
            Thank you very much for your help, it is greatly appreciated!!!
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              Budm is lurking around atm,let's see what he thinks (He's a master in this stuff) but I'm pretty sure we got all covered to blame the powersupply.
              • ROLEXrifleman
                Fire Hazard
                • Mar 2016
                • 34
                10-4,
                standing by
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Ion NP930XCJ-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930XCJ-K01DE boardview and NP930XCJ-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
