HP M9000, cap replacement
  • bcgrogbc
    • Jun 2015
    • 8
    Hello, I have an HP M9000 with a bungling cap which I want to replace, but I can't find any information about it to know what to replace it with.
    1800uF 6.3V "Gold Band" 105C FL [M] 86IVEJ
    Panasonic/Matsushita? 8mm width 21mm height, located near the CPU
    I have been trying to look at caps and wonder if EEU-FR0J182B might work as a replacement.
    Thank you for your time.
  • Wester547
    • Nov 2011
    • 1268
    • USA.
    Re: HP M9000, cap replacement
    Ouch....a bulging Panasonic FL. It has been seen here before, though, in that exact spot no less, more than once I think prior to this (and doubly on another board as well, but on an ECS board that has a hot running VRM). That area out of the board must run very hot to kill a FL (MCZs have been reported to have been blown in the same location, except it was every single one) and those freestanding FETs don't look like the best choice of thermal "solutions". I wonder if Panasonic has started to go down in quality over the past few years, though - there are several reports of prematurely failed FJS capacitors on this forum and others (several, though - not hundreds or thousands). Of course FJs have failed before too, but not without reason, to my knowledge. I've never seen a FL, FJ, FJS, or FJZ go bad myself without being overheated, but it makes me wary for sure.
    As to the replacement, FR might work but it doesn't look like that section is silkscreened for 10mm capacitors. And electrolytic capacitors have a negative temperature coefficient (at least with respect to ESR) which means you must be careful to maintain the even distribution of current between all those capacitors in parallel. That means remaining as close to the original specs (ESR and ripple current) as possible. No datasheet is available for FL, but I'd guess the ESR (for 8x20 case size) is somewhere in the ballpark of 12 - 16 milliohms and the ripple current around 1900 milliamps - 2350. I see what appears to be an 820uF 6.3v 8x11.5 KZG (rated for 36 milliohms and a ripple rating of 1140 milliamps) in parallel with all those 8x20 FLs, however, so it might not be an issue at all on second thought.
    • bcgrogbc
      • Jun 2015
      • 8
      Thanks for the reply. As to the failure, it was most likely due to heat, this particular computer had what appeared to be cat hair coating the heat sink fins.
      Yes it is an 820uF 6.3V at the end of that line of caps.
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        Also, KZGs have a high failure rate. You would also do well to replace those if the board is full of 820uF 6.3V KZGs along with the 1000uF 16V ones already present in the VRM input.
        • bcgrogbc
          • Jun 2015
          • 8
          Thought I would post a better picture. HP M9204f, M2N68-LA motherboard. Upper 1800uF 6.3v 8x21 Panasonic FL 86IVEJ has oozed from top.
          Caps are as follows: as best as I can see
          8 - 10uF 2.5V E85P
          1 - 330uF 6.3V KZE
          11 - 820uF 6.3V KZG
          6 - 1500uF 6.3V FJ
          6 - 1800uF 6.3V FL
          8 - 100uF 16V E87E
          3 - 100uF 16V KMG
          1 - 470uF 16V KZG
          6 - 1000uF 16V KZG
          I saw in another thread where they suggested the Nichicon UHM0J182MPD6 as a replacement for the Panasonic 1800uF 6.3V FL or is the UHZ0J182MPM6 a better match?
          Thanks again for your time.
          • bcgrogbc
            • Jun 2015
            • 8
            Oops, its an M9402f computer. I ended up replacing the blown cap with a Nichicon UHZ0J182MPM6.
            The computer lives again, I went with a minimal solution since I wanted to make sure it was the problem. The computer "had been" working fine. It was running fine (left on all the time), then was shut down due to bad weather. Upon trying to start up afterwards the cpu fan would start then off and nothing. Now it starts as expected and I may dismantle and replace the rest of the known "prone to fail" caps.
            Thanks to the help and input from Wester547 and a few posts here.
            • Jagster
              Panasonic SA-XR25,Looking for a good replacement cap
              by Jagster
              I have a Panasonic SA-XR25 surround receiver that is not working and I believe it may have a faulty capacitor. This large capacitor near the mains power input has a plastic top that is bulged out. Anyhow, I'm trying to find a like replacement but Panasonic doesn't seem to make this capacitor any longer and I want to find a suitable replacement. It has an "AUDIO" designation written which I presume means something important in relation to the capacitors design characteristics. Can someone advise on what would be a good replacement? Image attached.
              The sleeve info:
              10-27-2022, 09:34 PM
            • Andre Gilbert
              by Andre Gilbert
              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
              11-20-2024, 08:52 PM
            • Jacksoft
              Panasonic Viera TX-P46G10E 11 blink even after fan replacement
              by Jacksoft
              I have here a Plasma TV TX-P46G10E that before had a problem where it had issues with 11 blinks (FAN SOS) BEFORE starting normally. After that it works for all day long.
              It had some bad cold solder and I remade them all. After I replaced a fan that was half-dead (no RMP signal from the respective pin, but ok with 9V).
              Now the TV power up instantly and works perfect... only without the backplate!
              If the backplate is placed on the TV shutsdown after about 10min and start blinking with the 11 blinks. If I shutdown and re-powerup it starts blinking after a bunch of...
              11-26-2023, 07:22 AM
            • AquaMan Ua
              Problem with PANASONIC CF53 laptop after changing BIOS settings
              by AquaMan Ua
              Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
              05-17-2025, 09:40 AM
            • thuss
              Panasonic 55AS802b Mainboard replacement
              by thuss
              Hi
              My Panasonic turns on but wont go past the Panasonic logo.
              From what I have been told its a poorly designed main board that couldn't handle a firmware update.
              Panasonic want a whopping 350 pounds for a replacement board.
              I've been told that certain Seiki tv mainboards are compatible with my 55As802B.
              Any advice or which Seiki tv model has the compatible mainboard (I cant find one)would really be appreciated. (tried various combination of buttons but it wont go past the boot page)
              Thanks in advance
              12-29-2019, 02:23 PM
