I know these motherboards are pretty old by now, but I decided to post this just in case anyone ends up doing what I did. In my case, I got a Dell GX270 motherboard with bad caps a while back, but no original case. I managed to successfully fit the motherboard (along with its tray) into a standard ATX case. However, when it was time to wire up the front panel, I hit a wall.
Found some diagrams online which helped me get the power, HDD, and power LEDs hooked, though even with those diagrams I still ended up doing some trial-and-error before finally getting the LEDs to work correctly.
Eventually, I got my hands on a semi-dead GX260 PC. Took out the motherboard and front panel connector with accompanying USB/audio and power button boards, then started tracing with my multimeter. The final result:
https://www.badcaps.net/forum/attach...1&d=1406870758
Some notes:
* Pin 5, HDD LED(+), goes to a 200 Ohm resistor on the PCB that holds the power buttons. The other end of that 200 Ohm resistor is what connects to the LED's anode (positive) lead. Negative lead connected to ground.
* There are two (+) pins for the Power LED - pins 23 and 27. On the PCB with the power buttons, the power LED is actually a dual LED (orange and green, I believe). If you have just a single color LED, use pins 23 and 25, or 23 and ground (pin 25 is ground, so it doesn't make a difference where you ground the power LED).
* There is a USB disable(?) circuit on the USB PCB. It involves four N-channel SOT-23 MOSFETs, four 15 KOhm resistors, and a 100 KOhm resistor. I'm actually not sure if it's a disable circuit or what exactly, and neither know if USB ports will work without it. All I can say is that if the USB disable pin (pin 26) goes high, the D(+) and D(-) lines on both USB ports should get pulled to ground. With USB disable pin low, the MOSFETs should be high impedance, and thus the D(+) and D(-) lines should be uninterrupted and communicate with the board. So it probably would be okay if you connected the D(+) and D(-) lines directly to a USB port without this circuit. But I just put it there just in case.
* On the USB board, there are also "Intruder" and "External Speaker" headers. These should be self-explanatory, though
 (if not, let me know).
Hope this helps someone.
Some notes:
 I'd part with them very very cheap....like pay the shipping cheap!
