KDS lcd with bad caps
  • Earnman
    • Mar 2007
    • 3
    greetings all!
    i'm new here and a bit new to the concept of cap replacement...but i'm willing and able to learn!
    i have a 17" KDS lcd with a strange problem. when powered on, the display is fine for about 20 seconds or so but then goes black (power light stays green). if i power it off and then on again, the display returns, but for a shorter period of time. seems like the duration of a good picture gets shorter the longer the monitor is on to the point where it'll last about a second.
    so i cracked it open and discovered 7 bulging caps. six are 470uf 25v and one is 220uf 25v. i'm not afraid to attempt replacement, but i don't know where to get new ones. this site doesn't seem to have em in the 25v rating.
    any suggestions would be greatly appreciated!
    thanks!!
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Re: KDS lcd with bad caps
    Where are you located? The caps can be found here if you contact Topcat, or if you are in the states you can look at www.mouser.com or www.digikey.com.
    Ludicrous gibs!
    • Earnman
      • Mar 2007
      • 3
      i'm in the states. i sent a note to topcat (waiting for reply).
      meanwhile, i found a couple sites that have what i'm looking for, thanks for the suggestion. i found some nichicon's for .48 cents each. any thoughts on which brands are good and which i should avoid?
      thanks!
      • Earnman
        • Mar 2007
        • 3
        nevermind, i found the thread describing the good and bad manufacturers.
          Seasonic B12 BC-550 – barely 2 years old and with BAD CAPS already!
          by momaka
          I know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
          For today's considerations, I have a Seasonic B12 BC-550 [A551bcafh] 550 Watt ATX power supply for you (click on links for full size images).
          https://www.badcaps.net/filedata/fetch?id=3591771
          https://www.badcaps.net/filedata/fetch?id=3591772
          It's a modern ATX unit with fixed (non-modular) cables and an 80-plus bronze certificate. Here's the label:
          https://www.badcaps.net/filedata/fetch?id=359177...
          03-12-2025, 03:42 PM
        • eryjus
          Heathkit IO-4205 Power Supply Caps
          by eryjus
          First, I am a complete noob with high voltage stuff. I'm learning, but I need help by someone looking over my shoulder.
          I recently came into posession of a Heathkit IO-4205 5MHz Dual Trace Oscilloscope. The documentation is copyright 1978. I'm told it works.
          I opened it up to check the caps before I applied power, and found the following black caps and wanted to know what they were. They are on the power supply board. I was able to read the name and model and came up with, "Nytronics 162J-1, 0.1uF, 20% tolerance, 2000VDC."
          05-10-2023, 11:21 AM
        • Paxman_Swede
          Identifying caps on an old Zoom 9000
          by Paxman_Swede
          Hello!
          I have two projects on my work bench. One is a friends dead JBL Xtreme speaker with a blown voltage regulator and corresponding bulged and shorted cap. That cap has clear markings so I know what replacement I need for it.
          The other project however is a whole different deal. It's a Zoom 9000 guitar effect from the 90th that has developed a devil hound howl when there is no input from the guitar. I'm guessing caps problem. So, since I don't really use this effect anymore I thought it would be a perfect project to learn on.
          I have studied the board and...
          01-14-2025, 09:51 AM
        • captain150
          Help with switching power supply caps
          by captain150
          I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
          I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
