Buffer IC replacement, Samsung PN50B450B1D
  • johnboy1313
    • Nov 2012
    • 1959
    I picked up a Samsung PN50B450B1D this morning. It has the LJ92-01601A Y-main/buffer combo. The bottom buffer IC is blown. One transitor is failed shorted. I've ordered the repair kit from ShopJimmy. Hopefully, it'll work for me. Once I get the IC in place, what kind of glue should I use to cover the pins? Will hot glue work?
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Buffer IC replacement, Samsung PN50B450B1D
    Anyone?
      I would use high-voltage insulating epoxy. Hot glue is quite brittle under heat and might not work well.
      • johnboy1313
        • Nov 2012
        • 1959
        Right on. I'll look for a tube. I didn't know it existed. Thanks Tom.
        • johnboy1313
          • Nov 2012
          • 1959
          Would this work?
          http://m.ebay.com/itm/331069763628?cmd=VIDESC
          • johnboy1313
            • Nov 2012
            • 1959
            One more question. Can I test the tv without sealing the buffer or will it likely arc across the IC? I'd like to make sure everything's working before applying the epoxy.
            • freakaftr8
              • Oct 2012
              • 3743
              I have tested without sealing the buffer ic many times. I use grey permetex silicone
              • capkid
                • Oct 2010
                • 1339
                I've used this electronic-grade, non-corrosive silicone:
                http://www.amazon.com/MG-Chemicals-C...ywords=1035-ml
                LG Plasma Mal-Discharge Correction Service
                  09-07-2024, 05:50 AM
                • howardc64
                  Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                  by howardc64
                  • Prior owner tried a replacement main board. No difference.
                  • Samsung 2x red blinking standby LED = panel fault
                  • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                  • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                  • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                  07-19-2025, 10:54 PM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
