Plasma TVs -what do the various boards do?
  • SuperSkippy
    • Nov 2012
    • 58
    • United Kingdom
    If you google How does a plasma TV work, it's not all that instructive. Is there a web page anywhere that explains what (in Panasonic-speak) the SC, SU, SD, SS, C boards actually do?
    I feel like I understand how an LCD panel works, but I'm not so sure about plasmas.
    Re: Plasma TVs -what do the various boards do?
    SC = Scan and Sustain driver. Responsible for applying the Row Select voltage (-Vy) and the SetUp/SetDn waves. Also responsible for one side of the sustaining.
    SU = Scan Multiplexer, top side. Responsible for selecting between the Row Select voltage and the SC board's output for each line on the panel. Each chip is a 30~128 bit shift register (typically 64 or 90 bits). Data is clocked in at the top or bottom, and shifted up the panel. A "1" may be clocked in initially, to select the first row, this is then shifted along the panel to select each successive row. Then "0" is clocked in to all channels, possibly using the RESET line, so they receive the common sustain signal.
    SD = Same as SU but for bottom side.
    SS = Common Sustain Driver. Responsible for applying the Ve voltage and also for applying the other side of the sustaining.
    C = Responsible for feeding the signal from the control board to each of the panel data drivers, which load the actual image on the plasma panel.
    • twbranch
      Mad Nerd
      • Oct 2012
      • 153
      Good question and even better answer.
      • SuperSkippy
        • Nov 2012
        • 58
        • United Kingdom
        I started this thread yonks ago, and realised I never really did anything with it.
        I kind of get your answer.
        Basically what I know so far is that the panel is made up of rows and columns. To light a pixel, what happens is a high voltage is applied between the wires that make up a row of that pixel, and the wire that makes up the column. Then a spark goes between the two wires that excites the gas between them which phosphoresces, and what we see is the light that comes from this phosphorescence. I don't get what Row Select voltage (-Vy) and the SetUp/SetDn waves are, or what sustain is.
        Any help?
          What you describe is a DC plasma panel. Modern plasma panels are not DC because they have even worse efficiency than AC panels (500W+ for a 21" VGA display.) They are also a lot more expensive to make as you must use much higher voltages to drive the panel. So AC panels are used in basically every modern plasma TV.
          A plasma panel is a memory device, in a way very similar to LCDs. The panel is scanned one row at a time. The appropriate 1-bit image is programmed into each line. Va and -Vy are used to do this. Vscn, the other voltage, typically only a few volts above ground, is used to make sure the lines are deselected when they are not to be programmed. So to program row 500 of 1000, we'd make that row -Vy and all the others Vscn. This is the functionality of the buffer boards and panel COF drivers.
          The programming is at too low a voltage at this point to cause light emission. Instead, the programming creates a wall charge on the panel's pixels. Each pixel is kind of like a capacitor, storing an on or off state.
          When you apply a sustain waveform, you cause the pixels with a wall charge to conduct. Those without a wall charge do not conduct. Current flowing through the gas, at the breakdown voltage, causes the gas to emit light (sustaining.) The current causes the wall charge of each pixel to flip, so you must reverse the sustain waveform on each cycle. (Vs and COM are switched on each cycle.) The amount of light varies with the sustain frequency, panel efficiency, type of gas, etc. This is how an AC panel gets its name, the pixels receive an effective AC wave, varying from +Vs to -Vs.
          Since the display has inherent memory, you need to erase it. This is what the priming SetUp/SetDn waveform does. In addition, it liberates electrons from the plasma gas, allowing a much lower sustain voltage to be used, and increasing the chances of a successful discharge.
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • Erik Masters
            Panasonic plasma A boards/Kuro media box repair.
            by Erik Masters
            Hi all.
            I have 2 Panasonic plasma A boards for ST50 50"/65" and Kuro KRP 500A media box which needs repair.
            I'm not good enough at component repair so I need some help.
            A boards and especially Kuro media box is still very valuable and I can't throw it away like some average Joe,lol
            I'm from Europe/Slovakia and I'm searching for someone who is willing to repair these things or some tips at least.
            Both A boards have HDMI issue either no signal or flickering.
            And media box possibly with voltage regulator issue which is common...
            11-17-2022, 04:47 AM
          • ugamazing
            Apple M1 Boards & Exclamatory Error?
            by ugamazing
            We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
            Has anyone else run into this...
            02-20-2025, 09:24 AM
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • hopkok
            Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
            by hopkok
            Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
            3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
            I checked for low resistance on coils, no low resistance.
            Anyone with same issue like me?
            Thanks for any help.
            05-24-2025, 04:21 AM
