Goodbye Panasonic, it was nice knowing you.
    Panasonic PSU from plasma TV (42"), latest generation.
    http://i.ebayimg.com/t/Panasonic-Pla...Srw~~60_57.JPG
    Aishi caps. Among other less "well known" caps.
    I've pulled them from dead CCFLs.
    Now only Sony remain on the list of good TVs, and Sony suck, they make good TVs but as a company, they suck.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4959
    • New Zealand
    Re: Goodbye Panasonic, it was nice knowing you.
    At least they are easy to replace
    -David VanHorn
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      The PSU seems like a big waste of PCB estate. I hardly see any components. Maybe there's lots of SMD ones on the other side? Definitely doesn't look like a PSU that a Panasonic would make/use. I have a mainboard from a Panasonic CRT TV here that I use for pulling random parts from and it looks 10X better built than the above example.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4959
        • New Zealand
        I would say so. I can't see much stuff on the component side. Where are all the passive support components and the controller ICs?
        -David VanHorn
        • retiredcaps
          • Apr 2010
          • 9271
          From a troubleshooting and potentially soldering point of view, I would love to work on this board with lots of room versus the cramped ATX power supply.
          --- begin sig file ---
          --- end sig file ---
            It's definitely one of their parts, the PbF logo in the leaf is fairly unique to them. But it does look like Darfon designed and manufactured it for them.
            Figured out the green caps were Taicons from another shot (you can just about see "TAI" in this high res image:
            http://assets.shopjimmy.com/media/ca...K00006-TOP.jpg)
            Also the Sus boards for the PDP also had crappy Aishi on them.
            It's a real shame because the older Panasonics were built like tanks. I suppose they've make a record $10bn loss this year, so they need to cut back and try and make the businesses (like plasmas) more profitable. I hope it doesn't affect their nicer plasmas (such as the GT30.)
            It appears to combine the SS and side buttons with the PSU.
            Older Panasonic PSU: http://www.flattvparts.co.uk/bmz_cac...ge.980x619.jpg
            Funny, because I just saw a Sony sustain board from their older plasma displays. Made by LG (they usually use LG PDPs), but look - it has Nichicons. That's interesting because LG normally use Samwha on their sustains. I guess Sony told LG that they must use these particular components for long term reliability.
            I don't know why Panasonic don't use more of their own caps, but apparently it's cheaper to buy others in...
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Very true. I really do appreciate it when board manufacturers leave lots of space for caps and cooling.
              They used to is old equipment.
              Almost every component in that old CRT TV board I mentioned is made by Panasonic. It has Panasonic resistors, Panasonic polypropylene caps, Panasonic general purpose electrolytic caps, Panasonic inductors, chokes and transformers, and even most of the ICs are made by Panasonic (the headphone amplifier I built not too far back uses a Panasonic amp IC from that board).
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
