I got my hands on a Samsung 2693HM after the previous owner tossed it. I plugged it in and get the "2 seconds then dark" problem that seems to plague this monitor's smaller cousin, the 2493HM. I can't find any previous references of a 2693HM owner having the same problem, so appear to be treading in new waters.
Repro steps:
I've read as many 2493HM threads as I can find and there doesn't seem to be a definitive "gotcha" problem. From what I've read, it seems that the solid blue led indicates that the power board and logic board are likely to be working okay. That said, since this monitor's boards are significantly different enough from the 2493HM, I figured it warranted a new thread.
First, no bulged caps anywhere - I understand this isn't necessarily the only indicator of failure. I have a multimeter at home, so can bench test if I need to, but really dislike messing around in electronics with the power connected. I'll go there if I have to...
On the caps, the caps on the power board are the typical crappy Sam Youngs. Interestinly, the caps on the inverter board are signifcantly higher quality Rubycon ZL 220uF 35v and compared to the 24" monitor, has four as opposed to two caps (the 24" has 470v caps, BTW).
Given the symptoms, the assumption is that the inverter board caps have gone dry, but given that these are forum recommended replacement quality caps, I am less certain. I guess anything can fail.
I have also heard that the Slo-Blo fuses can cause issues, as well. I could buy new fuses or just jumper them to test, although not my first choice.
Question: Would (those in the know) just replace the 4 caps on the inverter board without testing or go through the testing battery first?
Pics below.
Thanks!
Repro steps:
- Connect monitor to computer
- Turn on - blue light stays lit
- Desktop shows up for a few seconds then goes black
- I can see images on the screen after it goes dark with a bright light shining on the screen
- Turning the monitor on/off consistently lights up the screen for the same short period, then goes black
Pics below.
Thanks!
