Re: CHIMEI CMV T38D - Buttons stopped working
So, on the chance that jetadm123 was right, I checked the cable for shorts - nothing wrong.
I figured this is time to look in depth at the button circuitry on the logic board. I tried to find a service manual for the monitor, but failed.
Then I remembered that the same PSU was used on some other monitors as mentioned by mockingbird.
I couldn't find one for the Viewsonic, and some photos on Google showed the logic board was different anyway
However, With the Acer AL2017 things got more interesting - one manual I got showed internal pictures pretty much identical to mine. Also, the logic board is listed as exactly the same part number! (A190A2-H-S1) ... but there are NO SCHEMATICS!!
A second manual had schematics, but they were wrong, and they actually appeared to correspond to the Viewsonic monitor (same numbers) Besides, they were not in vector format and all component values were unreadable
So, I figured I might as well try to draw one myself (for the button circuitry - it is attached below)
The schematic I have drawn is replicated for each button - each has this same circuit (but going to different pins on the OSD Controller IC, of course)
Because there are 6 Buttons, Rx, Lx, and Cx are each made up from 2x 4-way arrays.
While tracing the circuit I discovered that all resistors measured 10K Ohm (as they should have) except for the one related to the Auto Adjust button - it was a little low at 9.12k.
Aha! I thought, well - it doesn't seem low enough to cause a problem, but I desoldered it and checked it anyway - 10k, no worries
But why would it measure lower in-circuit?
Back to the diagram. If i've drawn it and understand it correctly, only 3 other things could be the problem. The inductor, the capacitor or the IC. Assuming the IC is fine (because replacement is probably going to be impossible), the problem must lie with either the inductor, or the capacitor.
The inductors all show less than 1 Ohm (taken in-circuit) (so they're probably not open-circuit? - but they may be short)
The capacitors are more interesting (taken in-circuit):
CP7 measures >2000k, 3.63k, >2000k, >2000k (relates to the Auto Adjust button!)
CP8 measures (rises to) 120K, >2000k, 1.13k, (rises to) 120k
I would have guessed all the capacitors should show infinity, so perhaps two of them are short, and two are leaky? I am just guessing there, though.
I guess if they were, I would see issues with the other buttons though. But they all function (at least in activating the Auto Adjust feature) and they all show 3.1v instead of 0.86v for the Auto Adjust button.
I know I should test them out of circuit but I don't really want to risk any damage as I don't know what I need to buy for replacements if that happened.
But of course, if they are broken already, I still don't know what to buy
Is there anything more I can do now?
