Login Problem Win 7 Home Premium - Locked Out
  • Toasty
    • Jul 2007
    • 4171
    Got a neighbors laptop this afternoon that has locked her out of Windows 7.
    Someone tried creating and using a Windows password reset disk, and was unsuccessful. Only works if you -previously- created the disk.
    Administrator account is -not- activated and there is no button or prompt to login as a different user. Differs from XP as you could Ctrl-Alt-Delete 2X and get a prompt. Not so here.
    Have used a password brute force to recover and it reports nothing for this account.
    Another utility to blank the password was run and I still can not login.
    Both password utilities reported the account as "Melanie" but on the login screen it says "MelanieElizabeth".
    The first utility says NT Password for the Administrator account is empty. I know the Administrator can be turned "on" from within from another User that has Admin privelages. Is there a way to "activate" the Administrator account without being "in" the system?
    Or, is there a way to create a User Account from the outside?
    BTW: Safe Mode does the same thing. No prompt to switch user there either.
    Toast
    EDIT: Another item worth mentioning. The first password tool lists the accounts and asks you to choose which User account to work with by entering it in hex (which it lists) or by the Name, in this case Melanie. Either way it is entered it says it is not a valid account. Huh? You just listed it for me, but it's not valid?
    Very odd.
    veritas odium parit
  • yyonline
    • Jul 2009
    • 692
    Re: Login Problem Win 7 Home Premium - Locked Out
    http://www.sevenforums.com/tutorials...ble-winre.html
    You can enable the built-in admin account from a recovery console (boot from Windows dvd.) It says to download a file to the desktop, but you can always pull the HD and hook it up to another PC to add the file, or use a USB drive, though I'm not 100% sure if the recovery console gives you access to USB drives.
    It also gives you directions for editing the registry to enable the administrator account by booting from the windows dvd and editing the registry.
    If it's a system with no Windows dvd, just a recovery partition, try a generic Windows 7 disc, it may allow you to boot into Windows recovery. If that doesn't work, you can pull the hard drive temporarily install it in another system, and follow the same directions to manually edit the problem PC's registry on another PC.
    Once you enable the administrator account, you should be able to reset that user's password.
    Good luck!
    • seanc
      • Nov 2008
      • 1319
      NTPass should do it.
      Just blank the password using * .
      Sometimes setting another password doesn't actually work, for some obscure reason. Blanking usually works.
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Find the free download for erd commander 2003 or 2005 (dont remember which), then use the locksmith utlity
        • Flababa
          • Oct 2010
          • 41
          I've used http://www.pogostick.net/~pnh/ntpasswd/ in the past. Maybe it'll work for you?
          I've had bad luck running it when packaged with other software, but had no issues when using it standalone.
          • Toasty
            • Jul 2007
            • 4171
            Blanking does not work. Tried that already. See first post.
            I'm not sure of W7, but does it allow you to use a nickname for the login screen?
            I do not understand why it has one name for the account and presents another for the login.
            Toast
            veritas odium parit
            • Flababa
              • Oct 2010
              • 41
              You mentioned blanking, but not the software / version you used. Also note that in the FAQ for this software, there are a few things that could cause it to not work properly. Improper shutdown, random code glitches (poor NTFS support), etc.
              There is also an option to lock / unlock accounts. Have you tried that on the administrator account?
              There are a few different software sets out there that do the same thing. Was asking to be thorough.
              And yes, it seems that you are able to create an account, then change the "display" name that will show on the login screen and start menu. The original account name stays the same.
              If I get a chance tonight, I'll burn a copy of the software and put a password on my laptop. It'll be Win7 Ultimate 32-bit.
              • Toasty
                • Jul 2007
                • 4171
                Solved!
                Flababa's solution worked. The 2nd software I used was LoginNow. It offered the same Linux prompts, but did not recognize the account. Your solution did and was 56mb smaller. Admin and user account now at login. I'm going to re-hide the admin as it should not be openly accessible.
                Thanks very much for the assist!
                Toast
                veritas odium parit
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  i know this is off topic, but say "flababa" out loud-its really funny
                  • joejoepop
                    Dell Pro Max 16 Premium MA16250 - Bios Admin is locked - help
                    by joejoepop
                    Code is J2G7VB4-8FC8
                    I tried using an online password generator and got nothing useful.
                    Bios admin is locked restricting me from even booting from a USB to install Windows please help I hope I haven't bricked this thing.
                    My organization puts the clamps down so hard on our stuff that we can't install any of the software we need, so frustrating. Our IT won't share anything with us.
                    10-31-2025, 09:22 PM
                    HP EliteBook 830 G6 + Backpack & Premium Wireless Mouse Notebook 800 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 830 G6 + Backpack & Premium Wireless Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Backpack & Premium Wireless Mouse boardview and 830 G6 + Backpack & Premium Wireless Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                    09-06-2024, 03:30 PM
                    HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook 800 Specification for Upgrade or Repair
                    This specification for the HP EliteBook 840 G6 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Backpack & Wireless Premium Mouse boardview and 840 G6 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                    HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                    This specification for the HP ProBook 640 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G5 + Backpack & Wireless Premium Mouse boardview and 640 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                    HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook 600 Specification for Upgrade or Repair
                    This specification for the HP ProBook 650 G5 + Backpack & Wireless Premium Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G5 + Backpack & Wireless Premium Mouse boardview and 650 G5 + Backpack & Wireless Premium Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
