Tiny Hexer macro scripts
    • 22293
    Tiny Hexer Scripts
    Copy DMI info easily with Hex editing software and Macro script
    https://www.badcaps.net/forum/showthread.php?p=1214739
    Tiny Hexer - https://www.softpedia.com/get/Others...ny-hexer.shtml
    Post your Tiny Hexer scripts in this thread, no bios requests or any other questions , just scripts that everyone can use for any bios with the same *DMI off-sets. Posting a thank you is ok though,if you find what everyone posts useful.
    The scripts can be named anything you want but the bios naming must be the same as they are in the guide when you make the scripts otherwise they won`t work.
    *DMI. The scripts don`t have to be just for DMI,they can be used for anything that uses the same fixed offsets.
    • 22293
    Re: Generic CopyDMI Scripts
    8MB - 8,192KB
    Off-sets 1000 - 2FFF (0x01000 - 0x02FFF)
      • 22293
      16MB - 16,384KB
      Off-sets 500000 - 501FFF (0x0500000 - 0x0501FFF)
        • 22293
        16MB - 16,384KB
        Off-sets 420000 - 421FFF (0x0420000 - 0x0421FFF)
          • 22293
          16MB - 16,384KB
          Off-sets 622000 - 623FFF (0x0622000 - 0x0623FFF)
            • 22293
            A useful script for members with no hex editing experience who want to rename and replace text in a bios, such as serial numbers.
            Copy or move your backup and the script into the C:\DMICOPY folder. Rename the backup to replacetext.bin. Open the script with any text editor to edit it. Replace the text 123456 with your own,then replace ABC789 with text you want to replace.
            The text you replace should be the same length !. Save and run the script .
            Click image for larger version  Name:	Edit script.jpg Views:	0 Size:	40.6 KB ID:	3218360
            Asus bios example.The serial number has been changed from M936NBCV00BKE7MB to M831NBCV000NALMB
            Click image for larger version  Name:	Replace Asus serial.jpg Views:	0 Size:	188.7 KB ID:	3218361
              • 22293
              A script to disable ram in the bios. An alternative to the SPD ram removal tool,which is reported to have viruses.
              This works ok for DDR4,works ok for some lenovo models,it could work with others,don`t know.It does exactly the same edits as
              SPD removal tool.Tested on 12 different bios.
              Edit: By default SPD removal tool pre-selects all of the SPD RAM sections for patching.This MPS script also patches all sections. If you
              want to remove sections seperately use a hex editor.
              1. Install Tiny Hexer,you`ll find a link to it in post 1 .
              2. Make a new folder on your C: drive called "DISABLE RAM" without the quotes ""
              3. Move or copy the bios and the "Disable RAM.mps" script to the folder
              4. Rename the bios to disableram.bin
              5. Run the script,a box should pop up saying how many replacements were made, click ok,close Tiny Hexer and save when asked.
              Give if it has worked for you
              • guyandpit
                • Oct 2021
                • 90
                • Philippines
                hi any guide how to use this script to change serial on my hp omen motherboard, sorry im not good in programming. thank you in advance
              • doivaythoiem
                • Jun 2024
                • 126
                • Việt Nam
                support DDR 5 ?
                  • 22293
                  Originally posted by doivaythoiem
                  support DDR 5 ?
                  I don`t know, i havn`t had time to check.
                  • f@brice
                    • Nov 2019
                    • 78
                    • France
                    for DDR5, it seems memory zone start with 0x3010120304 (hexa) and size 0x400.
                    il someone can confirm and / or test.
                      • 22293
                      I can confirm it starts with 301012 , the next byte 03 i think is SO-DIMM , for desktop RAM its 02 .
                      • f@brice
                        • Nov 2019
                        • 78
                        • France
                        it seems length isn't alway 0x400, in found it could be 0x138 in asus some bios...
                        • f@brice
                          • Nov 2019
                          • 78
                          • France
                          i found some ram bloc references starting with 300912...
                          • kodox
                            • Jul 2017
                            • 330
                            • Indonesia
                            thank's for the script, it worked on Lenovo IdeaPad 3 15IML05 bios which is use a DDR4 onboard ram, but i don't remove the chip from the board
                            Last edited by kodox; 01-29-2025, 11:04 PM. Reason: forget the detail done to the board
                            • bonnie52098
                              • Aug 2024
                              • 1
                              • IDN
                              thanks, wor on x415da
                              • mauri1990
                                • Jun 2021
                                • 5
                                • argentina
                                Thank you, worked perfectly on Lenovo V330 15ikb
                                • Agus “Aguss07”
                                  • Feb 2025
                                  • 2
                                  • argentina
                                  Hi! it gives me error
                                    • 22293
                                    Did you rename your bios to disableram.bin .Check if you have a double file extension disableram.bin.bin
                                    • saop94
                                      • Apr 2019
                                      • 1
                                      • mexico
                                      Thank you very much, it bring back to life my lenovo s145, so easy and safe to use
                                        by SMDFlea
                                        Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                        Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                        02-28-2023, 02:14 PM
                                        HP factory bios patcher
                                        by SMDFlea
                                        * DISCLAIMER: badcaps.net and its members do no support unlocking stolen or company-owned devices.
                                        * The unlock scripts given here are for personal use only, ie. you accidentally set a password on your own
                                        * machine,you forgot the password you set a long time ago or you mistyped the password when setting it
                                        * and cannot get in again.
                                        10-20-2024, 12:52 PM
                                      • chth96
                                        Is it possible bridging tiny broken trace
                                        by chth96
                                        When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                        cutting tiny trace.
                                        This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                        Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                        But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                        12-03-2022, 11:32 PM
                                        LENOVO ThinkCentre M72e Tiny ThinkCentre M G470 Specification for Upgrade or Repair
                                        This specification for the LENOVO ThinkCentre M72e Tiny can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M72e Tiny boardview and ThinkCentre M72e Tiny schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-12-2024, 03:36 PM
