HP 17 DAY11AMB6E0 revE repair request
  • baddjavo
    • Jun 2018
    • 88
    • Serbia
    I found that 19v pins of flat cable was broken, so i connected with wire, but still nothing. cn2 pins1,2. Display now have 19v.
    U2, L8 no stuff, so pin1 float. pin3=3.3v, pin4,5=3.3v
    resistance on cn2, pin4=100k, pin5=82k, pin40=9k
    Voltage not coming on cn2 pin40,4, before bios change.
    My bios backup is attached
  • baddjavo
    • Jun 2018
    • 88
    • Serbia
    Re: HP 17 DAY11AMB6E0 revE repair request
    Need bios for lvds version, cant find model name faded.
    • dexxter_sat
      A battle between DAY11AMB6E0 revE and a newbie
      by dexxter_sat
      My first repair try...
      Hp pavilion 15, no light, not charging.
      BQ24738H:
      1. 0,8v
      2. 0,8v
      3. 0,8v
      4. 0,8v
      5. 3,0v
      6. 14,0v
      7. 0,33v
      8. 0,47v
      9. 0,47v
      10. 0,14v
      11. 2,1v
      12. 1,1v
      13. 1,1v
      14. 0
      15. 0
      16. 6v
      17. 6v
      18. 1,1v
      19. 1,1v
      20. 19v
      When i bypass P020 mosfet, laptop works but neither charging nor using battery. Any hints?
      [Mod. Edit] Schematic -> https://www.badcaps.net/forum/show...
      10-20-2023, 03:48 PM
    • baddjavo
      HP 17 DAY11AMB6E0 revE problem
      by baddjavo
      Yesterday i got hp 17inch laptop, no power wont start. Dead.
      After pressing pwrbtn 3x blinks white led on dc connector.
      No 3.3v, no 5v because nothing on enable pin 1.
      s5_on signal missing.
      LDO 3.3v on pin 5 and LDO 5v on pin 7 outputs are good.
      pwrbtn 3.3v good.
      schematics and screenshots attached....
      03-21-2023, 08:00 AM
    • Loki_Fido
      BIOS request for HP ENVY x360 2 in 1 Laptop 13-bf0002TU PLEASE
      by Loki_Fido
      Hi ya folks,
      Hope everyone's having a good day.
      I have a HP ENVY x360 2 in 1 Laptop 13-bf0002TU with nothing on the screen.
      The laptop starts but no display. Connecting to an external monitor give me nothing too. Ive attached my original backup bios
      Make HP ENVY x360 2 in 1
      Model 13-bf0002TU
      S/N CND3171C5T
      Prod ID 6L2F0PA#ABJ
      I looked up at this site before writing this request. And there was a link. But i couldn't download any files from it.
      Any moderator could look it up, if possible? It says, "Invalid file...
      06-16-2025, 08:02 PM
    • mindoverflow
      ASUS GTX 1650 Gpu.Initialize Interrupt request line stuck asserted
      by mindoverflow
      hello,
      there is an asus gtx1650 which displays fine in windows but if i run a benchmark test it displays artifacts and the driver crashes after a second or two.
      I changed pads and thermal paste.
      I run mats test but it is reporting 0 errors.
      I then tried to run the mods version 400.271_1650 test, it first ran and stopped with a 'breakpoints limit reached after 5 retries' error and the fans went full speed.
      After a reboot, I tried to run the test again, but now the test fails and says "ERROR: Couldn't clear GPU's interrupt...
      02-09-2022, 03:22 PM
    • ebyte64
      Bios request for Acer P214-52-58CH
      by ebyte64
      Good day.
      I would like to request a bios for the following laptop?
      Model: Acer P214-52-58CH
      Model No: N19Q7
      S/N: NXVLHE0H11204BA27600
      SNID: 11201936276
      Symptoms: Laptop powers on but no picture on screen.
      I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...
      09-25-2024, 05:59 AM
