Dell Precision T1650 MT Workstation bricked after BIOS update
  • trix11
    • Jan 2020
    • 4
    I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
    - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
    - Dell Precision T1650 mid tower Workstation
    - Xeon E3-1225 V2
    - 32Gb PC3-12800E RAM
    - 4Tb SATA HDD
    - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
    I see now that others have experienced like issues e.g.:
    - https://www.dell.com/community/Preci...d/td-p/7278685
    Coincidentally, my flash process also stopped at exactly 33% and similarly denoted "Updating your system's firmware cancelled".
    I waited an hour before powering off, after which the unit powers on with flashing orange power-on/off button only, system fails to POST, system fan ramps to max speed , no display or response to peripherals, etc.
    Draining power/state, removing CMOS battery, pulling RTCRST jumper, removing RAM/all peripherals/cables, etc. saw no change in behaviour.
    I've since removed the motherboard and identified the two SOIC 8-pin BIOS chips each printed with the following:
    - 25Q03213 EC0 VS CHNG0027 315A (e4) - Micron/Numonyx/ST flash chip "N25Q032..3E" (32MBit / 4096 kB, SPI)
    - 25Q064A 13EC0 (e4) 99 CHN 317023 - Micron/Numonyx/ST flash chip "N25Q064..3E" (64MBit / 8192 kB, SPI)
    After some initial googling, my first course of action was to dump the content of both chips.
    This was performed using flashrom on Raspberry Pi (Raspbian GNU/Linux 8 (jessie)) fitted with an 8-pin SOIC clip.
    For anyone interested, chips were only detected with ATX power connected to motherboard (system not powered on).
    Three reads from each chip with no diffs between resultant images confirmed consistent capture.
    -rw-r--r-- 1 root root 4194304 Oct 25 12:21 32-orig-read1.bin
    -rw-r--r-- 1 root root 4194304 Oct 25 12:23 32-orig-read2.bin
    -rw-r--r-- 1 root root 4194304 Oct 25 12:25 32-orig-read3.bin
    -rw-r--r-- 1 root root 8388608 Oct 25 12:27 64-orig-read1.bin
    -rw-r--r-- 1 root root 8388608 Oct 25 12:29 64-orig-read2.bin
    -rw-r--r-- 1 root root 8388608 Oct 25 12:31 64-orig-read3.bin
    I've also extracted the various firmware from the Dell .exe using:
    - https://github.com/platomav/BIOSUtil...date-extractor
    For former BIOS T1650A27.exe, this produced:
    -rw-rw-r-- 1 root root 6291456 Oct 24 16:57 1 T1650A27 -- 1 System BIOS vA.27.bin
    -rw-rw-r-- 1 root root 16384 Oct 24 16:57 1 T1650A27 -- 2 Gigabit Ethernet v1.3.bin
    -rw-rw-r-- 1 root root 65536 Oct 24 16:57 1 T1650A27 -- 3 Legacy Video OROM v2.1.3.2.bin
    -rw-rw-r-- 1 root root 121856 Oct 24 16:57 1 T1650A27 -- 4 Legacy RAID OROM v11.2.0.1527.bin
    -rw-rw-r-- 1 root root 7843840 Oct 24 16:57 1 T1650A27 -- 5 Intel Management Engine Update v8.1.72.3002.bin
    -rw-rw-r-- 1 root root 418 Oct 24 16:57 1 T1650A27 -- 6 ACPI OS support v4.0.0.0.bin
    -rw-rw-r-- 1 root root 4 Oct 24 16:57 1 T1650A27 -- 7 Intel AntiTheft v3.0.0.18.bin
    -rw-rw-r-- 1 root root 91 Oct 24 16:57 1 T1650A27 -- 9 Model Information v1.0.0.0.txt
    For latest T1650A28.exe, this produced:
    -rw-rw-r-- 1 root root 6291456 Oct 24 16:59 1 T1650A28 -- 1 System BIOS vA.28.bin
    -rw-rw-r-- 1 root root 16384 Oct 24 16:59 1 T1650A28 -- 2 Gigabit Ethernet v1.3.bin
    -rw-rw-r-- 1 root root 65536 Oct 24 16:59 1 T1650A28 -- 3 Legacy Video OROM v2.1.3.2.bin
    -rw-rw-r-- 1 root root 121856 Oct 24 16:59 1 T1650A28 -- 4 Legacy RAID OROM v11.2.0.1527.bin
    -rw-rw-r-- 1 root root 7843840 Oct 24 16:59 1 T1650A28 -- 5 Intel Management Engine Update v8.1.72.3002.bin
    -rw-rw-r-- 1 root root 418 Oct 24 16:59 1 T1650A28 -- 6 ACPI OS support v4.0.0.0.bin
    -rw-rw-r-- 1 root root 4 Oct 24 16:59 1 T1650A28 -- 7 Intel AntiTheft v3.0.0.18.bin
    -rw-rw-r-- 1 root root 91 Oct 24 16:59 1 T1650A28 -- 9 Model Information v1.0.0.0.txt
    I've reviewed the forum's suggested reading below that touches on DMI editing, though nothing is listed for Dell systems:
    - https://www.badcaps.net/forum/showthread.php?t=103526 BIOS Guides, methods, resources and tools
    Armed with original corrupt images and extracted firmware, I'm seeking assistance with the Dell-specific process/specifics of how to repair/modify/produce a viable set of firmware images to flash the system with.
    Any/all assistance is greatly appreciated.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11717
    Re: Dell Precision T1650 MT Workstation bricked after BIOS update
    Post your original corrupt bios file here.
    • trix11
      • Jan 2020
      • 4
      Here you go - thanks!
      • hoaca388
        Badcaps
        • Jan 2022
        • 11717
        Precision T1650
        Service Tag: BGV66Z1
        • trix11
          • Jan 2020
          • 4
          @hoaca388, thank you so much for quick and superb effort.
          I'm happy to report that since flashing the system with your modified images, I'm back up and running again (now with latest BIOS A28).
          I am indebted to you sir! +1
          • akwky
            by akwky
            Hi!
            04-14-2025, 01:56 PM
          • lordgeny
            z490-f gaming bricked after bios update
            by lordgeny
            I had to assemble a PC with this Z490-F Gaming motherboard and an i7-1700K CPU. Upon the first boot, the CPU LED was red and flashing. I realized that I needed to update the BIOS. I didn't read the ASUS notice that said, "Before BIOS update, please download Intel ME update tool from ASUS support site, and update ME firmware to Version 14.1.53.1649V1.1 to ensure optimized system settings." I updated the BIOS without doing this, and everything seemed fine until the system performed an Intel ME update and shut down permanently. My attempts to reflash it were unsuccessful. Searching online,...
            11-02-2023, 09:03 AM
          • test.it
            Failed bios update on a Dell Precision 3650 Tower
            by test.it
            Can anyone help me with a failed bios update on a Dell Precision 3650 Tower, service tag G01WWM3. The reason for the error was a power failure during the update. System no longer boots, no POST....
            01-28-2025, 07:32 PM
            DELL Precision T3620 Precision E3-1240V5 Specification for Upgrade or Repair
            This specification for the DELL Precision T3620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T3620 boardview and Precision T3620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
            09-12-2024, 03:44 PM
            DELL Precision T3620 Precision i7-6700 Specification for Upgrade or Repair
