Onkyo TX-SR607 replacement volume control encoder
  • redwire
    • Dec 2010
    • 3910
    I had an Onkyo SR607 with a volume control encoder not working, turning the knob up the volume number would move around crazy and not work reliably.
    Took it out and apart and no, it's not oxide or cleaning, lube required etc.- the metal is simply worn out. It's a 30mm part with metal bushing.
    Volume control encoder Onkyo P/N 25065655W, Alps EC12E2425 is some oddball variant I could not find. I did the dig and tried replacement part Alps EC12E2420803 and it works/fits just like the original. Mouser 688-EC12E2420803 for $3.00
  • crackedprint
    Sony HCD-HX80R Amplifier Volume Control Problem
    by crackedprint
    I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
    I have tried a Cold Reset as per the service manual.
    I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
    I have looked all the way through the service manual and tried many online...
    01-21-2025, 12:18 PM
  • madan1
    Cambridge Audio azur 540r volume control problem
    by madan1
    Hi everyone.
    I have a Cambridge Audio azur 540r and face the following problem - from time to time the volume can be set only to VOL MIN and VOL MAX ( from both the volume knob and the remote ).
    The volume control IC is BD3816K1 and it is controlled by the CPU M5964C40J.
    The volume knob VOL_A and VOL_B signal enters the CPU and is processed to VOL_DATA and VOL_CLK which go straight to the volume control IC ( I believe the remote control signal also goes the same way ).
    The CPU is powered by a stand-by transformer with constant +5V ( 7805 ).
    The VOL IC
    11-01-2018, 12:55 AM
  • Dannyx
    Simple volume control for audio amplifier ?
    by Dannyx
    Good day folks. I want to run a Bose subwoofer and some random speakers on my PC at home. I don't have an amp for this project yet and I was looking for decent solutions and I figured I could very well run them on a car amp. Why not a regular hi-fi amp ? I figured a car amp would fit better under my desk. I looked at a Sony XMN1004 which is relatively affordable, yet of decent enough quality and with good reviews overall. Conveniently enough, this Bose Acoustimass 5 Series II sub (what a name) I have has two drivers inside, each with its own separate terminal, so I can hook it up to the Sony...
    12-27-2020, 10:17 AM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
  • Storyteller12
    Samsung Soundbar Q900T Cuts Off if Volume above 30
    by Storyteller12
    I have this soundbar and when I turn it on it works until I turn the volume above 30.
    Then the display show “PROT” protection and shuts off.
    I can turn it right back on and it works until volume hits 30 again.
    There is a little static on the surround speakers so I unplugged them but still have same problem. I tried unplugging all speakers also and when volume goes above 30 it shuts off.
    I can turn the volume above 30 if nothing is playing but as soon as I play something it shuts off.
    It will play fine for hours with volume...
    03-21-2023, 12:31 PM
