ONN 100012588
Issue: No Power, Then Rebooting After Main Board Change
Short answer: replace main board and power board
Technical answer: replace main board and Q306 & Q307 on power board.
Long answer:
TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge. That's not right. Took my time discharging it and the rest of the board. C334 had good ESR, so why isn't the board discharging the voltage itself? Poked around, poked around, found that Q306 and Q307 are blown (MBRB20100CT DIODE SCHOTTKY 100V 20A) were blown. Weird again. TV turns on, shows a picture, but the power board is still bad? First for me.
Replaced power board and all is well now. When benching the TV, do NOT connect to the network as it will not allow you use it as a regular tv afterwards unless you register it.
Long answer:
