Another tango with the 17mb82s
  • snoptel
    • Dec 2021
    • 49
    Hi guys,
    I have a cheap LCD TV with a VESTEL PS and a 17mb82s board.
    Outta de blue the led flashes red 7 times, the back light comes on for a second and starts this loop over again.
    Been reading about re-flashing the eprom chip and how they have to be frozen in order to load the USB.
    Any input from the fellow hackers in the forum?
    Thanks.
  • Diah
    • Feb 2013
    • 6446
    Re: Another tango with the 17mb82s
    try first the for_clean_nvm
    Format the pen in FAT32 and unzip the file to the pen (one file upgrade_loader.pkg ) , turn off the TV. Insert the pen into the TV and press the Ok button on the remote control. While holding down the key, turn on the tv at wall until the standby LED blinks rapidly. wait for the tv to boot so you can remove the pen
    • snoptel
      • Dec 2021
      • 49
      Thanks for the reply.
      Both RAR files have the same file inside, do I do the same process as you describe for both files??
      • Diah
        • Feb 2013
        • 6446
        both they are same end file name.. but they are different version... and file size.. this way i wrote try first the rar one.
        • snoptel
          • Dec 2021
          • 49
          Thats what I was thinking, just wanted to confirm.
          I'll let you know what the outcome is.
          Thanks.
          • snoptel
            • Dec 2021
            • 49
            Hi Diah, thanks a million..it worked.
            Why a TV would lose it´s EEPROM settings blows my mind...geez.
            Cheers!!
            • Diah
              • Feb 2013
              • 6446
              Cheers!!
              because its Vestel and master with dancing not only Tango but Cha Cha too, LOL
              • edugimeno
                • May 2017
                • 581
                • Spain
                Hi there.
                I have a Vester MB82 tv set that startes blinking (6 times-pause-repeat) as soon as you press the power on button on the remote. I checked this method just to see if this is a fw issue, but no matter which file I put into the flash drive, it does nothing when I plug it in while holding OK button. STBY led lights up solid and flash drive (which has an internal LED) shows it hasn't been powered up. I tried 3 different flash packages (all unzipped, single file in drive, formatted FAT32...)
                Any idea what could be wrong?
                EDIT-> Used a different flash drive (older), and it WORKED!
                Thanks!
                • snoptel
                  • Dec 2021
                  • 49
                  Originally posted by edugimeno
                  Hi there.
                  Thanks!
                  Vale
                  • pcbmaniac
                    VESTEL 17MB82S not working only red led working
                    by pcbmaniac
                    Dear friends,
                    i do have a VESTEL 17MB82S not working. Here is the story:
                    First, when i give power on tv, red led lights after some blinkings and i've noticed that picture apears but no backligt at all (i use a small light to see it).
                    Then i do flash with a FAT32 USB stick, the upgrade_loader.pkg file with the known OK button method. After that, the TV stops and when i press the ON-OFF button from remote control, the red led goes on but no backlight no picture at all.
                    I do took off the 2 flash IC's U10,U12 try to read them with flash programmer, but i get "Error...
                    10-15-2023, 03:01 PM
                  • Davy no Caps
                    Vestel 17MB82S EEprom dump required
                    by Davy no Caps
                    First time trying to fix a TV for a friend, it's a Bush DLED32165HD.
                    Power Board - 17IPS11
                    Mainboard - 17MBS82S
                    Panel - VES315WNDB-02
                    Red blinking standby light is on steady, press power button on remote and light flashes 7 times then stays steady, press power on remote again light flashes 10 times and then goes off.
                    Checked all the voltages on the power board inc backlight circuit, they all read ok and are stable. Backlights tested with backlight tester and all work fine (2 strips x11LED on each).
                    No picture, backlight or sound just blinking...
                    06-06-2025, 03:22 PM
                  • ugura09
                    Next Minix Hd Tango DUMP 21,05,2023
                    by ugura09
                    Next Minix Hd Tango DUMP 21,05,2023...
                    05-21-2023, 09:08 AM
                  • eniac22
                    Vestel 17MB82S Firmware
                    by eniac22
                    Hello, i need firmware for Vestel 17MB82S, panel VES315WNDA-2D-N11....
                    02-24-2022, 10:48 AM
                  • cruiser_
                    Vestel 17IPS71 + 17MB82S - no standby
                    by cruiser_
                    hello there,
                    I am trying to fix a Walker 40 TV - it has Vestel 17IPS71 3R3 as PSU and 17MB82S for logic.
                    How I got here...
                    The TV had shorted USB connector, which I fixed. TV turned on. Ran for a few hours on HDMI input. Started to see some dark dots/patterns on the screen as seen on the photo.
                    I restored to factory setting. The TV has rebooted only to a blinking standby LED. It sat there for a number of minutes after which I disconnected it.
                    Now, after plugging it back in - there is not even a standby LED.
                    My 17IPS71 provides 12V, no standby...
                    11-25-2021, 12:48 PM
