these are without battery? (strange voltage), now post voltage with battery and power supply and if it was with battery, now post voltage with only power supply.
I just looked at all the posts but I haven't found the solution to my problem yet.
I have a 2011 MBP with a board of 820-2936B
It works well except for the battery charge and the charge indicator green light on the side of the MBP.
The problem is the battery does not charge and the green charge level indicators do not light up.
When the macsafe is plugged in, the green LED lights up and turns red during pends 4s then it goes back to green with or without battery.
I replaced ISL6259 but nothing always changed the same failure.
I checked the resistance R5280 input and output = 3,468V
I checked the resistance R5281 input and output = 3,468V
I checked the resistance R7051 input and output = 12.4V
I checked the resistance R7052 input and output = 12.4V
I measured at Q7055 terminal 1,2,3 = 12,4V
terminal 4 = 12.37V?
terminal 5 = 5v which drops to 0V?
By testing in diode mode on SMC_BSA_SDA = 0.492 ohms
and SMC_BSA_SCL = 0.480 ohms
on CHGR_BGATE = 12.37V instead of 5V?
Does anyone have a solution to my problem thanking you
thank you
