HEET44WW_PCH.bin should I write it in CFEON EN25QH64, HEET44WW_Main.bin should I write it in CFEON EN25QH32 but where should I write it and how HEET44WW_EC.bin?
How do you program these Dump files into the Bios? Does the bios chip need to be removed? Or can these files be flashed within windows with flasher software?
Why would you want to flash a dump if your laptop boots to Windows.
But answering your question - no, usually it doesn't have to be removed but you still need an SPI programmer attached to the bios chip. Newer laptops can't be programmed with dump files within an operating system.
Because I have a E531 that someone put a stupid supervisor password on the bios. So now can only make minor changes to the bios settings. I found a flash that would clear out the supervisor password. But sounds like I will need to have a programmer attached which I don't have.
