Hello i have a HK - AVR130 with the following problem: Its stuck in standby and won't turn on. I have checked some resistors and can't find visual damaged capacitors, i have no idea where the signal goes to when you hit the standby button (it should turn on and show blue lights) wich cable or where it ends to measure it. the 5 resistors i checked should be 0.47ohm and they are around 0.43ohm and 0.51ohm (think that means they are not broken)
Also ive checked pin 1 and pin 8, they should have 5 volts, however pin 1 gives back 0.461v? << don't think thats correct (not sure how to read that value) pin 8 gives me 05.02v (i believe this is correct?)
Ive seen more HK's on this forum but not exactly with this problem. Hopefully someone can help me out.
Help is much appreciated!
PS. Ive attached photos of several components with text to explain what i did.
