LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
    Hello
    Please can anyone unlock Bios
      Originally posted by mielta View Post
      Hello
      Hello try this patch from your original file.
      Good luck ...
        Works
        Thanks a Lot
          How did you solved the problem? I have the same problem. L390 nothing but beeping
          Originally posted by CornholioGSM View Post
          Hello hello,
          i have here L390. Dump from bios (25Q128) was verified, patched and flashed back.
          Problem is , that i have nothing os screen - i can hear only ugly melody
          HDD was removed, tamper switch not found on mobo
          *****SOLVED******
            Hello All,
            I have a t470 (Type 20JM-000BUS) with an svp i am trying to unlock. I successfully gotten to the TPM certificate reset, erased the bios chip then reflashed the original bios, opened up the computer, hit f1 to enter bios and... the svp is still there? I've attempted 3 times with no luck. Does anyone know what im missing?
              Originally posted by dresq1027 View Post
              Try this. If it doesn't work, you'll need someone else's help who is smarter than me. All I did was ran it through the patch program on page 1 of this thread.
              Thank you for your help . Unfortunately, it didn't help. The computer beeps
                Originally posted by neonchaos View Post
                Hello All,
                Here are copies of my bios and patched bios...
                  Looking for some who can remove SP password from BIOS, the machine is T14 G1 AMD ID:TP00103G , Type:20UE-S0VT00. I have CH431 and TTL866 Plus.
                    Please help me with my T560. I make all off with instruktion but not funktion.
                    Sorry for my bad English.
                      Originally posted by b0n3v View Post
                      Looking for some who can remove SPV password from BIOS, the machine is T14 G1 AMD ID:TP00103G , Type:20UE-S0VT00. I have CH431 and TTL866 Plus.
                      I try to do factory reset and now have 0199 error for too many tries of SPV, can I reset(disable warning) only this to make it boot again? Is this setting is stored on some "easy" eeprom?
                        Worked perfectly on a X1 Yoga 3rd gen. Mucho gracias
                          I figured it out! I had to remove the locked drive only AFTER i flashed the original bios back. Then i could boot from a usb. Fyi for anyone else that may have this issue.
                            can someone help me to remove the SP Password from Bios from my
                            ThinkBook 14s Yoga ITL - Type 20WE ?
                              Good day, tried this earlier on one of our laptops. I managed to patch it and flash in BIOS setup. After placing the original bios.bin the laptop does not turn on. Laptop is Lenovo T470
                                Does this method also work with Think Centre desktop Systems? I have an M920q with an i5 8500T that needs SVP clearing so I can disable Secure boot, to run Linux
                                  Hello!
                                  Is there a way to remove the T590 bios password? I've seen a few videos on YouTube, but none of them are detailed. They are obviously keeping the secret
                                    Max Power 3, thank you very much
                                    it worked on a lenovo T440s
                                    worked perfect tested
                                      is to easy, i unlock the x2800 with this method, sae help this video
                                      https://www.youtube.com/watch?v=AX_e9jlhbAg
                                      its the same but anyther lenovo.
                                        T590 can be tried with this method described in this post
                                          Use "Search this Thread" tool:
                                          https://www.badcaps.net/forum/showpo...postcount=1948
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
