HP ProBook 645 G1 Bios dump
    Can somebody share dump for HP 645 G1
    Or instruct me how to edit BIOS file from HP site. I downloaded bios but it is empty with serial, model etc... and when I turn on laptop it always says that following data is missing.
    So I have my old bios dump (locked) and new from HP site without those data.
    Eprom dump will solve my problem because serial no is not important to me but knowing how to edit HP bios will be much more useful.
    Thank you!
    Re: HP ProBook 645 G1 Bios dump
    send old bios.
      Old bios attached.
        Try this and reply.
          Works perfectly, thanks!
            Originally posted by imranromi View Post
            Try this and reply.
            thank's bro
              hi friend the file works 1000000%%%%
              thanks alot
                can I have file smc.bin of HP probook 645 G1
                uuid: BFE4D8B0026FE8119D9D2FC85F0680B9
                S/N: CNU417CTDD
                  Hi, Can somebody share dump for HP 645 G3?
                    The full 16MB bios is available from hp. Extract the files with 7zip or winrar,or run the exe it will give you the option to save the bios .
                    https://ftp.hp.com/pub/softpaq/sp870...00/sp87045.exe
                      cool, thanks, this is the only i cand do? i descompressed the file with winrar...
                      in the list of archives the bios is the .BIN no?
                        Yes,the .BIN is the bios file.
                          thank you very much, later I try it and I tell you
                            Hi SMDFLea, this works perfectly ! thank you, grettings from argentina.
                              Thanks works perfect!!
                                Hello
                                How to use the file I wiped all the data on the Fat32 USB flash drive and moved the file to it and the device does not enter it nothing after pressing the Start button and the top and bottom arrow button and the power button does not enter the file nothing happens
                                What do I do
                                I use Linux
                                apologize for the language problems
                                  thanks
                                    Try this and reply.
                                    may GOD always bless you sir, thank you very much
                                    although this post has been 2 years ages
                                    you help me solved my problem
                                      Originally posted by cvorke View Post
                                      Old bios attached.
                                      thanx bro but password bios ?? !!!!
                                        use the next post...#4
