My Sonos Playbar wouldn't power on, a typical power board issue.
I tested the rectifier and the MOSFET with a multimeter. I had to desoldered the MOSFET to ensure I got an accurate reading and it tested good. Used fresh thermal paste for the heatsink and resoldered it to the board. The rectifier tested good on board and wasn't removed.
I replaced the two 400v 100uF capacitors that looked suspect and know to fail. The ESR meter table doesn't have a 400v capacitor listed so I just replaced both with the same. The smaller capacitors tested good with an ESR meter on board.
Nothing else looked suspect on the power board.
Screwed the whole unit back together (whew) and it came back to life!
I used the Playbar for about 45 minutes at a normal level without any issues and shut it down as I was done listening to it. I unplugged the unit.
The next day I plug the unit back in and it's dead again. No power.
It wasn't plugged into the same outlet when it first failed. So it's not an outlet issue.
Totally perplexed.
Any assistance would be greatly appreciated.
Totally perplexed.
