lenovo edge E530 white screen
    Hallo.
    Have this Lenovo Edge E530 that boot just to white screen
    reflashed bios, but nothing changed
    tested with known good lcd. when in white screen, brightnes controll work
    also nothing on hdmi
    i realize that +VCC_GFXCORE_AXG is only 0.45v
    i have uma gpu so i dont know it is enough
    Re: lenovo edge E530 white screen
    GFXCORE at 0.45V is ok.Check LVDS pinout voltage.
      Check the LVDS voltage as @mcplslg123 said ,the LVDS cables fail on these ,and theres problems with flexing around the left hinge, vent .
        while checking voltages i found this q2102
        ckecked both sides for short
        in little time i dont find that mosfet so i just jumped s-d and picture comes on
        just search on boards for replacement
          Any SOT-23 P channel mosfet should do as long as its rated at the same or better spec
          https://store.comet.bg/download-file.php?id=6908
            I'd say change the screen. I had many cases where a white screen came from a defective screen.
            But in your case it is the mosfet.
              Remember everyone for any laptop white screen problem
              white screen always come when 3.2 volts not going to any LCD or LED fuse
              All LED have two fuses one have 19 Voltage and One is 3.2
              so you can check voltage on fuse if not showing complete 3.2 then always display will come white screen
              in the upper case you show in pic there is one transistor that is burn from middle just check which pin have 3.2 voltages then just make a jumper to the other side where is only 1 pin
              after the jumper i think your problem will solve
