I have an intel motherboard that has 3 leaking 1800uF 6.3V KZJ caps near the ATX connector, and from reading this forum I have found out that the replacement for these would be the Nichicon HN 6.3v 1800uF 8X20mm caps.
However, I was wondering if it would be ok to use poly caps instead, particularly the Nichicon LG Polymer 6.3v 1800uF 10X13mm.
I also noticed this board has 5 KZG caps (470uF and 680uF 16V) which from what I gather here, should also be replaced. What would suitable replacements for these be? Looks like the 470uF ones would be replaced with Nichicon HN 470uF (Am I correct?), but for the larger capacity 680uF there seems to be more choices at capking (Rubycon MCZ, WXA, UCC KZE and Nichicon HZ)
There are also a lot of small 470uF 6.3V KY caps, not sure I want to touch those as they all look fine and there are too many of them.
