I recently bought a used car with the factory sound system still intact. Unfortunately there was a lot of snaps, pops and distortion with the volume cranked up. Being curious, I disassembled the power amp and saw quite a few caps inside They looked fine, all Nichicons RS, VX and VP series. Since I had a few low esr caps and a "so what if it doesn't work cuz it sounds like crap anyway" attitude I replaced the 2 2200uf 16v RS series caps with 3300uf 16V panny FM's. The snapping and popping disappeared! Still distorting though. Pulled the head unit out and replaced the chemicon 2700uf 16v SXE with the same value panny in the amp. No more distortion! I know this isn't a very scientific approach and no idea if low esr caps are even recommended for this type of application but so far the results have been heartening. The system will probably blow up next week though..
After reading Pete S's post about metal foil resistors, I may try to replace the existing one's in the power amp with those. I just need to know if there's an easy way to determine the wattage rating of the resistors.
