My grandpa has this TV, it turned off with a bang and flash one day. Opening it up revealed soot and burn marks on the heatsink of the primary mosfet, but no short circuit and the mains fuse intact.
There is a 0.33 ohm resistor between the diode bridge and primary filter capacitors, that measured open. I replaced that with a ferrite bead and plugged the PSU in, it went bang again, but nothing blew open anymore. I then removed the mosfet and primary heatsink, cleaned up the soot and plugged it in again. Bang and flash. This time the source of the flash was easily identifiable - the snubber capacitor going between the drain and the source of the mosfet. The capacitor is 150pF 1kV and looks like an Y class cap, but isn't. There are no safety markings on it. Y caps should never fail short.
I removed this capacitor, reinstalled the primary heatsink and mosfet and put the PSU board back into the TV. It powered up and works fine. Another fairly solid design let down by cheap parts...
