Hey @all,
i'm a very happy user with my Onkyo Receiver but yesterday Channel R was exploded and smoke come out of the receiver.
After opening i saw the two broken AMP Transistors TTA0001 and TTC0001. I also checked the Pre AMP Board and found a lot of broken parts in there. The SM from elektrotanya helps me to find all errors and parts.
After ordering all parts i removed the broken ones and replaced all parts with the new ones. I changed also the white resistor in front of the TTA/TTC which was broken too.
After i think everything was good i tried to perform a first test. Powering on without the Pre AMP Board. Good idea because i works again. The Relais were clicking and the Receiver turned on. I'm very happy and everything seems Ok. The Receiver was not getting warm after testing a while.
Then i turned everything off, remove the power cord and install the Pre AMP Board.
I build one cable with two 100k resistors for measure the idle current and clamped this cable to the Voltmeter. First to the broken Channel R.
Carefully i turned the receiver on and it works. The Voltage after turning on was 4mV. I adjust it to 2,5mV like the SM says. And so i checked one channel after the other, adjusted every channel and everything seems Ok. After 4-6 min. warm up time I adjusted again to the values named in the SM. But the values are not reached. The SM says adjust from 9 - 11mV L/C/R Channel and from 6 - 8 mV all other Channels. I'm turning the adjustment potis to the max. and i'm getting max. 8mV at L/C/R and 5mV at the other Channels. I'm not sure to turn the potis to much.
After waiting a while everything looks good.
But the Pre AMP Board was getting very warm and so i thought it was better to turn the receiver off.
Later after testing i was going to the living room, install the HDMI Out cable from my Receiver to the Flatscreen and turn the receiver on.
Not a good idea because a loud Bähhhm and smoke comes out from the R Channel. Damn it!! What was happened? I cannot explain myself.
Then I disassemble the whole Receiver to measure every part again and the whole problem was coming back. TTC/TTA, the capacitor and all the parts on the Pre AMP Board were died again. But i had replacement parts in stock. Measured everything and changed everything again.
And again everything is looking good after turning on without Pre AMP Board. Now i checked all parts on the Pre AMP Board again and it looks good.
Then i installed the Pre AMP Board again and turn the receiver on. From the first time nothing happened and it will turn on on is working like it should. But after a few seconds little bit of smoke is coming from the Pre AMP Board (SL Channel) so that i turn it off and remove the power cord as soon as possible.
Nevertheless some parts like in the R Channel were died, this time in the SL Channel, and i have to remove them too.
So, before my next try to burn some components again i will be sure to remove every error from the Pre AMP Board and adjust the idle current before turning on.
Can anybody help me in this case? How to adjust all the potis for idling without installing the Board and how to check the whole Pre AMP Board correct to prevent the next explosion?
Thanks and best regards
