Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting Game Consoles & Other Weird Devices
Old 08-28-2010, 01:46 PM   #41
Toasty
Toasty's Avatar
City & State: East Coast, USA
Line Voltage: 220-221
Default Re: Identifying badcaps in a Xbox360
What model is the system? Age?
MCZ is typical in these nowadays.
HZ is also typical. HZ(M) is the proper marking and should be under the (-) negative stripe and above the H0732.
If yours has the yellow Fujitsu 820uf/4v, and you managed to damage them, you've really gone beyond the extreme in roasting. BBQ anyone?
Toasty is offline   Reply With Quote
Old 08-28-2010, 02:29 PM   #42
migu3l
It was manufactured in 2007. Its not the first gen model because it has HDMI, but its fairly old.
I don't have 820uF/4v caps, only nichicon and rubycon 820uF/6.3v. I only damaged the ones around the CPU (4 of them are buldged, another 4 have leaked and 4 of them have looked like it had a volcanic eruption). I had the heat gun on for 4-minutes, which seemed long but I blindly followed the YouTube guide anyway.
Normally I would just give up and buy a new Xbox, but I live in Australia where its a PAL region. I got my system from the states and have some games with it already. On the plus side it seems like a good learning experience.
migu3l is offline   Reply With Quote
Old 08-28-2010, 04:51 PM   #43
Toasty
Toasty's Avatar
OK. They changed the Fujitsu's for Rubycon's.
Heat gun method requires a ~carefully~ cut-out, 2 layer aluminum foil shield that blocks everything the chip(s). If you just blasted away without the shield, there's the problem. Same happens with the "oven-bake" method. Just put the new caps and you should be in good shape. Until it RRODs again...
Look into building the foil air tunnels that channel the fan draft over the GPU and CPU. Also consider investing (~$25) in the newer GPU heatpipe style cooler that places a second coil in front of the CPU cooler airflow. A fan upgrade to the Talismoon LED fans (just the regular ones, not the Turbo-switch style) is $20 well spent. A 60% increase in air volume without an increase in noise level (actually a 3dB decrease) is nice too.
There are loads of mods out there. Some make sense, some are a waste of time. YMMV
Toast
Old 08-28-2010, 05:06 PM   #44
Toasty
Toasty's Avatar
EDIT:
...foil shield that blocks everything but the chip(s).
Old 08-28-2010, 11:47 PM   #45
migu3l
Toast
Thanks Toast
I'll look into the other mods, I have a Talismoon on its way and Ill try the aluminum shield duct.
When I heat gunned I did cover the caps with foil, although I just threw a sheet over it rather than securing it properly. I really rushed it because I wanted to get the thing fixed already.
Old 08-29-2010, 12:13 AM   #46
mockingbird
mockingbird's Avatar
I was looking to replace the yellow Fujitsus in my Xenon with equivalent Sanyo Oscons. Are the Fujitsus already Polymer eventhough they have a K-Vent?
Also, the 2700uf Rubycon MFZ... What would you guys recommend replaceing them with as this value is a little out of the ordinary.
...Their plight, in fact is even worse, they don't realize that they're cantonists, they think they're free men. What a slavery that is - to confuse slavery for light, and bitter darkness for bright light.
-Rabbi Menachem Mendel Schneersohn
mockingbird is offline   Reply With Quote
Old 08-29-2010, 12:34 AM   #47
Toasty
Toasty's Avatar
Yes,they are. Fujitsu FP caps are now under Nichicon branding.
Nichicon HZ, Ruby MCZ, Nichicon HN.
Or, you go nuts and poly the entire board.
Old 08-29-2010, 01:50 AM   #48
mockingbird
Good, so I don't have to worry about replacing those. They're all near the GPU which gets very hot. The Rubycon MFZ are 6.3v 2700uf. I can't find anything with that value that low ESR on Digikey.
Which polymer caps would you recommend?
Old 08-29-2010, 02:25 AM   #49
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Originally Posted by mockingbird View Post
Are the Fujitsus already Polymer even though they have a K-Vent?
Sorta.
They are "Functional Polymer" as opposed to "Solid Polymer".
They've pretty much kept what "Functional Polymer" is a secret [trade secret I guess] so the need for the vent unknown.
The early versions [made before 2003-ish - guessing] occasionally had problems where moisture from the air would slowly leak -in- and cause minor bloating but since then the seals have improved.
That may have been the only reason for the vent as the very new ones don't have vents anymore.
[I've replaced bloated ones on boards made in 2000-2001 and seen them on boards made from the late 90's thru 2001-2002 or so.]
There is no performance difference or known longevity difference between them and actual solid polymer anymore.
Just consider them the same as solid polymer.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 08-29-2010, 02:29 AM   #50
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
http://www.mouser.com/ProductDetail/...mZ8C%252bg8%3d
Old 08-29-2010, 02:33 AM   #51
mockingbird
Ah, these are Nichicon HZ... But do you know what polymer series would be a suitable replacement? Also how do HZ compare to UCC LXZ or LXY?
Old 08-29-2010, 03:06 AM   #52
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
To compare caps look at ESR and Ripple
http://products.nichicon.co.jp/en/pdf/XJA043/e-hz.pdf
ESR - Less is better [may say Impedance in data sheet vs ESR]
[ESR is *like* a caps resistance to Ripple. Since these caps job is to pipe Ripple to the ground plane less 'resistance' to Ripple is better.]
Ripple - More is better
[Ripple rating is *like* a caps watt rating. - Tells you how much ripple it can handle without overheating internally. - Kind of like a measure of how heavy duty it is.]
Look at data sheet for the 2700uF HZ:
ESR = 7 mOhm @100kHz [or 0.007 Ohm @ 100kHz]
Ripple = 3770 mAmp @ 100kHz
[This is a very high grade of low ESR cap.]
Now go look at ESR/Ripple for LXZ & LXY.
These are much lower grades but still good brand and low ESR.
Digikey has none for poly that size.
Mouser just crashed. Can't check there on poly.
If they have a 2700uF 6.3v poly you may have to give up your first born son or a body part to get some.
Old 08-29-2010, 03:19 AM   #53
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Mouser is back. - All they have in poly @2700 is a 4v.
You would have to check actual voltage in all system conditions.
If it never goes over +4v [including Ripple] then the poly would work.
http://www.mouser.com/ProductDetail/...nyKaom4Q%3d%3d
Old 08-29-2010, 03:48 AM   #54
mockingbird
Hmmm. Nichicon LG. Looks good. I would be comfortable replacing with 4v . Next time I open it up for the JTAG. I want to hack the NAND to modify the I2C default fan settings. Thanks.
Old 08-29-2010, 03:51 AM   #55
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
You need to check the volts in the circuit.
Good chance it's a 5v circuit and that will toast a 4v cap in no time.
Old 08-29-2010, 03:58 AM   #56
mockingbird
Ok, I will try and ask around on the xbox-scene forum. They've a hardware mod section but oddly enough, I've never seen anyone attempthing a poly mod. Especially on Falcons, they don't even have the Fujitsus around the GPU but Nichicon HN!!! (Yes I know HN is good after '05/'06)
Old 09-16-2010, 09:49 PM   #57
migu3l
Hey guys,
I just received my replacement caps from badcaps.
However they are significantly smaller in size to the original damaged caps.
By significantly, I mean nearly half the size of the original ones.
The specs are same but is it suitable to replace the damaged capacitors?
Cheers
Old 09-16-2010, 11:04 PM   #58
mockingbird
What did you order and what are you replacing?
Old 09-17-2010, 12:57 AM   #59
migu3l
Hi mate,
I ordered the Rubycon MCZ series 820uF 6.3V.
They are to replace the current ones which are Rubycon MFZ and nichicon capacitors both 820uF and 6.3V. However the current ones are around 22-24mm in height and around 8mm in diameter.
The MCZ capacitors I recieved are only 12mm in height and the same diameter
Old 09-17-2010, 01:16 AM   #60
mockingbird
The MFZ are 2700uf, this will not work. Also where did you get your Rubycon MCZ, not off eBay I hope. If you did, they're fake.
