Badcaps.net Forum
Go Back   Badcaps Forums > Troubleshooting Hardware & Devices and Electronics Theory > Troubleshooting TVs and Video Sources
Thread Tools Display Modes
Old 08-27-2019, 03:49 PM   #1
MerlijnD
City & State: Overijssel
My Country: Nederland
I'm a: Knowledge Seeker
Default Lg 60pz570 No picture, No sound, No Z-Y voltages
Hi people,
Got my hands on a sweet 60 inch plasma. Guy i bought it from showed me live at his house: Turn on, relay clicks, faint glow until you turn it off.
So I went online, searched and found around the same model and people saying cracked solder etc, fused. So I wasn't smart and just took the boards apart as im a "electronics hobbyist". Indeed 1 or 2 cracked solder points. Fets measured OK from a quick check on my end, so did the fuses.
Resoldered the points, replaced one "starting to bulge" capacitor, and put the things back in. But now it does nothing anymore. As in: Turn on, relay clicks but no faint glow anymore. Just black screen.
Baseline:
Zsus
Incoming:
All in spec
Outgoing:
VZB: 0.9v
Ysus
Incoming:
All in spec
Outgoing:
VY: 0v
VSC: 0v
When disconnecting Ysus board power ZSUS VZB 0V.
When disconnecting ZSUS board power Ysus both test points still 0v.
Led on logic board blinks Long-Long-Short-Pause-Short
Not quite sure how sensitive these boards are, but incoming 5v = 5.16v. Not sure if thats within spec.
Disconnecting LVDS and jumping ext_auto_gen:
Zsus
Incoming:
All in spec
Outgoing:
VZB: 5-9V
Ysus
Incoming:
All in spec
Outgoing:
VY: 5V
VSC: 5V
Nothing on screen. Faint coilwhine from ZSUS board, double powercycle on ZSUS board (10 seconds in between, 2 seconds slight coil whine per cycle), Tv turns off after that.
I have literally no idea what's wrong, yes it was stupid to not test the voltages when it still had the dim glow, but instead i fixed the solder cracks first. Anybody know whats going on?
Greetings,
Merlijn
MerlijnD is offline   Reply With Quote
Old 08-27-2019, 04:14 PM   #2
R_J
City & State: ☻
My Country: Canada
I'm a: Professional Tech
Default Re: Lg 60pz570 No picture, No sound, No Z-Y voltages
Start by rechecking every connection you soldered, you may have shorted a couple connections together. Post some pictures of the y-sus and otherboards you worked on.
R_J is offline   Reply With Quote
Old 08-30-2019, 02:32 PM   #3
MerlijnD
Hi, I've rechecked everything and i am 100% certain all is good. No solder blobs, in EXT-AUTO_GEN mode it sounds like the ZSUS board wants to start (9V coming out) or something but the YSUS board seems completely dead (2V coming out).
All of the SMPS voltages are bang on (except the 5v (5.16v)) with the label on the back.
Reseated connects, and measured buffer boards. Found no direct shorts to ground.
Pictures attached.
Old 09-02-2019, 04:19 AM   #4
MerlijnD
Quote:
Small update, I mucked around with my hairdryer. Warmed up the ZSUS and Control board. Behavior changes a bit, relais in SMPS got a bit spastic and i got 55V on the ZSUS board for a brief moment.
18v control is present on YSUS board 1-2 seconds after startup. Then its gone again (so is the static noise/coil whine).
Old 09-11-2019, 01:15 PM   #5
MerlijnD
Well it wasnt the logic board, replaced that. Same issue, same blinks.
Disconnecting 1 or the other buffer board didn't make any difference.
Old 09-12-2019, 01:52 PM   #6
MerlijnD
Well I measured the 18v control signal on the ZSUS board, measurus 4.5v.
The 15v outgoing rails from the YSUS (guess this is boosted to 18v normally?) is dead, same 4,5v.
Now I don't know when these voltages should be there, if they should be there during startup or if they are controlled by the logic board.
From reading other threads regarding the missing 18v, i've seen people talk about the voltage regulator, sadly this is on the back of the board for me, so I can't measure it while on.
Does anyone know if it's worth it to blindly replace the 200D6 pwm switching controller IC, or am I looking at the wrong IC here?
Looked at this thread: https://www.badcaps.net/forum/showpo...9&postcount=18
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2019
Powered by vBulletin ®
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
