I have a 820-2849-A which has the following symptoms:
Screen output is cut in half, the left side being on the right and the right side on the left, with a black void in the middle. Pictured is the Apple Hardware test running from a USB stick:
Problem is not with C9560, it is holding a nice 1.845v against the ground from the moment the board powers on.
Trying to boot to macOS hard crashes and computer restarts.
I used to be able to disable the Nvidia GPU by EFI shell commands, which would restore the screen back to normal and I could boot to macOS and use the computer, but this is not working anymore after a 6 month hiatus from using this machine.
Would anyone recognize this issue and be able to tell is the GPU fked or can this be salvaged somehow, and point in the direction what to check next?
thanks.
thanks.
