JVC LT48N530A no image or sound power supply OK
    This is a Chinese clone or re-badge despite the JVC name.
    No image or sound. Nothing visible with the flashlight test. Tried accessing HDMI ports and playing a movie with no signs of audio output. Voltages on power supply seem to come up OK. The LED tell-tale on the front of the TV reacts to remote button control and goes from red to green in an expected manner.
    The LED backlight voltage gives a clue. At initial power-on it is sitting at about 35VDC. Then it briefly goes up to about 150VDC (about what I'd expect) before quickly cascading back down to ~35VDC.
    So, do you reckon I have failed LED string in the panel? If so, why can't I see an image with the flashlight test or get some sort of audio output via the HDMI port?
    There is secondhand mainboard available for sale but I'm reluctant to invest in that if I actually have a defective panel.
    Re: JVC LT48N530A no image or sound power supply OK
    That sounds like a bad/open backlight string/s. Don't worry about not seeing anything with the flashlight test. Try looking when the menu is up. Sometimes it escapes us to see the flashlight test work.
      Any other votes confirming it's likely to be a failed LED string in the panel?
        At the time the voltage went to 150vdc you would see the backlight if it was working, so very likely open led.
          Yes RJ, not even a flash from the LEDs. I did tell the seller that it was my suspicion and therefore she needed to accept there was little value in the set other than a few spare parts. Thanks all. Time to strip it down I think.
            Check for a bad led, It might only need one replaced, might be an easy repair
              Just to close off the thread, I stripped it down, and checked the LED strips. 3 failed LEDs in total. So it was a panel fault.
