This TV would not come out of standby. I replaced shorted diode D607 on the power supply board and the set worked fine for a few days then quit again with the D607 shorted again. All the caps on were Sam Young and they looked fine to the eye. But I decided to replace them all since that brand is on the "Bad Caps" list. That did the trick and the set has been working fine for several weeks.
LG 47LM4600-UC 47 inch LCD TV With Sam Young Caps in Power Supply
Re: LG 47LM4600-UC 47 inch LCD TV With Sam Young Caps in Power Supply
Good repair job.
Electrolytic capacitors can fail without any external signs.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.
I just fixed one of these. Had standby light and 164v across main cap. I tested diode D607 and it read short in circuit. Pulled a leg up and it was good. 1 inch away from it I saw the remains of a small blue cap. There was another one very close by, a 101k.
I pulled one off a junk board and transplanted it. A working tv!
First of all thanks to the guys that posted about this issue with this TV, it really simplified determining what the problem is. And just to add some failure background, I was watching this when a fairly loud pop occurred and the TV went black with no sound.
That said, I am hoping for some help identifying the value of the capacitor. It does not have any numbers on it and I have been unsuccessful in locating a parts list for the Lg 47LM4600. The part can be seen in first photo (C603) and has a black burnt mark in the middle of it. D607 read shorted as previously mentioned but OK when one lead lifted.
Thanks in advance for any inputLast edited by RDC55; 08-07-2019, 02:33 PM.
Originally posted by diif View PostC603 is a 220pF 1KV you can upgrade it to a 2KV.
Just to add C610 main cap 160V standby and 395 operating.Last edited by RDC55; 08-10-2019, 12:46 PM.
