Toshiba 49L310U screen half white half black
    I'm trying to repair my son's TV by following several Youtube videos. Original problem was no picture but there was an image if you shine a flashlight at an angle. There was audio but there were also no backlights. I replaced several LED strips and after reassembling the TV they worked. When I powered up the set there is a brief flash of light on the screen but no picture or image. Thinking I had incorrectly inserted the data ribbons from the T-con into the panel boards, I tried removing and replacing the two ribbons. Now when I power up I get a screen that is half white and half black (or dark). I've tried this a few times and end up with either no picture at all or the half screens.
    I would greatly appreciate anyone's input on what I might be dealing with at this point. I did replace the Power Supply board first before the LED strips so I'm in for a bit of money already.
    Thanks to everyone for any suggestions.
    Re: Toshiba 49L310U screen half white half black
    Check for around 12 volts on each side of tcon fuse, negative probe ob metal/chassis back, positive probe on each side of fuse, to see if that section is still ok.
