Hello everyone, so the problem is the tv would seem to power up when i hit the power button as i would hear a relay click, sometimes it may give me a good picture for about 5 secs or so, sometimes i get a black screen, then shortly after it will click back off and i get power and opc lights flashing together twice followed by one flash of the opc light then it repeats.
Please correct me if i'm wrong but i understand the flash sequence indicates a possible power supply problem, can anyone say if this is accurate information? So going on that i went ahead and tried a factory reset, checked all caps,checked for any loose soldering and finally tried replacing tny274(someone suggested i try this) - same problem.
I have a strong steady 5v as the flash sequence is going on, absolutely no other voltages on any of the other pins/connectors.
I would appreciate anyone's suggestion on what it could be, going on the info i gave, if it could be power supply, mainboard or some issue with the ccfl lamps, yeah, it's an old tv.
A few pics :
A few pics :
