.. found the manual .. 2 blinks is panel error
search yandex ..
Samsung+UN65NU6900F+Chassis+UEZ83.pdf
.. psu voltages are normal .. tv cycles backlight on and off 5 seconds .. 2 blink code
.. disconnecting both flat cables from mainboard and the TV stays on backlight and the CPU is running .. no hotspots or faulty voltages
.. disconnected one side then other flatcable from t-con .. the tv stays on .. black screen no images and backlight running .. no blinks when one or both t-con cables are disconned
.. visual inspection .. nothing bad on panel driver boards .. 3.3v going to eeprom chip
.. will keep checking further today with more results .. next up is probably MLCC's on panel board .. would really hate to waste a 70 incher
search yandex ..
