Viore 26" LCD TV Backlight Inverter issue
    Hi everybody, I have a 26" Viore LCD here Model LC26VH55. It was showing a picture and rapidly flashing the backlight for awhile now its just dark. I can see it is displaying images with a flashlight. So I'm guess i'm in for a new inverter board right? the one inside is stamped CMO I260B1-5UC-A001B / T87I027.09 / 27-D024386. Do I have to replace with the exact board or can I switch to one thats close like this one:
    http://cgi.ebay.com/VIZIO-VA26L-BACK...item56436069ebf
    its very close just wondering since I am so new at this,
    Thanks!
    Re: Viore 26" LCD TV Backlight Inverter issue
    If you are going to be a regular member here, please use the manage attachments feature to upload your picture and please do not post inline. There are several reasons why as stated below
    https://www.badcaps.net/forum/showpo...5&postcount=12
    --- begin sig file ---
    --- end sig file ---
      OK sorry I didn't know how to do that, will do from now on!!! Thanks retirecaps
        1) Did you check to see if there are any SMD fuses on the inverter board? If yes, do the fuses measure less than 1.0 ohms?
        2) Did you check the secondary inverter transformer pins to see if the ohms readings are within 3% of each other?
          will check and report back asap, thanks again
            OK it seems there are 3 SMD fuses on the board although they are labeled F2-F4, they all report 0 ohms resistance.
            Each transformer reports back very close, definitely within 3%.
              If I were designing a board, I would starting numbering with 1. That said, check for a F1.
                OK I found it - F1 0.75A / 76V, test 0 ohms,, the other 3 are white this ones black it was blending in
                  1) Your photos are too low in resolution to see the part number, but try checking the 8 pin IC for shorts. You will have to read the part number and look for its datasheet.
                  There are 6 of them. There are 2 ICs "sandwiching" each of the 3 caps on the inverter board.
                  2) What brand and make are the caps. You could try changing them?
                    OK the mosfets are AO4614, I'm new at this and trying to decipher the datasheet on how to test them. is it "Static Drain-Source On-Resistance" or "Gate Resistance" i'm going for? My multimeter is a fluke 179 and always wants to "auto range" is this ok or should I always set it manually?
                    The caps are as follows:
                    1. (no name?) KZH 35v 390uf
                    2. Nichicon HV 35v 270uf
                    3. Rubycon ZLH 35v 390uf
                    Thanks,
                    Jared
                      See section on MOSFETs at
                      https://www.badcaps.net/forum/showpo...0&postcount=13
                      Nice multimeter! Leave it at auto.
                      KZH is made by United Chemi-con (brown sleeve with a little "crown" symbol).
                      All 3 caps brand and series above are quality low ESR as per
                      https://www.badcaps.net/forum/showthread.php?t=2280
                        thank you very much retiredcaps for being so helpful, i'll check the mosfets tomorrow morning an post results.
