Jetway P4XFA (LEX BN266A)
    these boards were both labeled as LEX BN266A but they are only Jetway P4XFA relabeled. If you remove the label, you will se Jetway model number.
    I found both of them in the trash (sorry for my English), with lots of stability problems. I decided to analyze them, maybe take off battery, flash eprom and any useful part. Cpu pwm capacitors were vented! GSC capacitors... not all were vented, but many of them. All capacitors on the board are GSC
    See photos for details.
    Only the 1500uF 6.3V seem bad, they're vented.
    All other capacitors in the board, also the 1500uF 16V on the CPU PWM section seem ok.
    bye
    damtech
    Re: Jetway P4XFA (LEX BN266A)
    don't apologise for your english, it's fine. And I'd say they're worth recapping.
    The great capacitor showdown!
      Welcome to the forums! GSC are of terrible quality. It is much better to recap the board if everything else checks out fine. I would recommend that you replace all the GSC caps though, for cheap insurance.
