Confusion about replacement HDMI port
    Hi guys, apologies for the noob question. I have a Denon AVR-920S with a bad hdmi output port. Looks like the prior owner tried forcing it in when the alignment was off, it pushed the plastic center piece back and broke some of the connections to the board.
    My struggle is in finding a replacement. The receiver supports hdmi 2.0a/hdcp 2.2. When I search digikey they only spec compliant ports they list are 1.4. I vaguely remember reading something about a licensing dispute, so that could be it. I understand hdmi 2.0 is a hardware upgrade from 1.4. Are all of those hardware changes after the signal gets to the port? Or put another way, does the connector version not matter?
    Alex
    Re: Confusion about replacement HDMI port
    No, the port doesn't matter, it's the signal, cable and hardware to decode that change.
      Thanks for the confirmation!
